On 8/24/2019 at 5:22 PM, Duski said:
Why do I have 3 fan slots in the front when there's no opening to take or exhaust air? And I can also mount 2 fans at the bottom, would it help me with anything? I only have 2 at the top and 1 in the back set to take air from outside.
You can do what I did and hack one or more holes in the front panel and cover them with a fan grill. They come in many shapes and sizes to help with your customizing needs.
Below is the fan grill/filter I used.
https://www.newegg.com/p/1YF-0028-00002?Description=fan grill&cm_re=fan_grill-_-1YF-0028-00002-_-Product
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1097620-case-fans/#findComment-12851629
@Senzelian My case is a local brand and it's called MYRIA MY8737
My specs are I5 8400, RX 580 8 GB and 16 GB RAM. The temperatures are average but sometimes they go a little too high which is kinda annoying because I feel like I'm in a sauna. I was playing Battlefield V today and the temps reached 75-76*C for both the GPU and CPU (stock cooler). I would really like to have lower temps, maybe 60-65*C.
@VIVO-US So would it make a difference if I install 3 front fans? Even though the front is not ventilated I have a little opening at the bottom, here, I took a picture of it.
@MadAnt250 It sounds good but I'm afraid I'll fuck something up lol, I always do..
https://linustechtips.com/topic/1097620-case-fans/#findComment-12852443
19 minutes ago, VIVO-US said:
As long as that small opening at the bottom isn't blocked, adding fans to the front could help a little with airflow.  Adding fans to the 2 openings on the PSU shroud could also help circulate more air to the graphics card.
Oh I see, thank you. Should I place them to intake or to exhaust air?
https://linustechtips.com/topic/1097620-case-fans/#findComment-12852632
Your temps are fine and what you're aiming for is needlessly low. It's not bad to want lower temps but there isn't much practical benefit.
https://linustechtips.com/topic/1097620-case-fans/#findComment-12853805
Now that I see the case, maybe one or more fans up front can help a little bit if you can remove what ever is going across the holes.
System specs below
PSU: Corsair CX650M
https://linustechtips.com/topic/1097620-case-fans/#findComment-12854039
