27GL850-B... Monitor Help!
Sordxyx
I plan on buying the 27GL850-B.. However the only place that sells it is Overclockers. Why are they the only sellers. Its supposedly an amazing monitor yet only they sell it.
Can someone check if it is true to its spec as well as if its worth it or not? Maybe there are better ones! Dont wanna buy a crap monitor for that price. Cheers
https://www.overclockers.co.uk/lg-27gl850-b-27-2560x1440-nano-ips-144hz-1ms-freesync-g-sync-compatible-widescreen-led-gaming-monit-mo-155-lg.html
Another note! What is the difference of the b version and normal version
2 hours ago, Glenwing said:
They're the same monitor, -B just means black, sometimes it is left off the name.
Thank you. Saved me a lot of hassle!
