Is that $180 exclusively for the motherboard, or are you expecting to get any modern CPU+motherboard for under $200?
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
Well, considering that overclocking isn't a strong suit for any AMD chip, (they come from the factory with PBO which gets you within 1% of the performance of the tweaked to precision manual overclocks, and no stability issues to boot) any X470 with heatsinks on the VRMs should do the trick. Thing is, you can get decent X570 motherboards for under $180, and they'll handle the overclocking great.
What would be ur suggest for x570 boards?
1 hour ago, dgsddfgdfhgs said:
isnt that the lowest end barebone x570 from asus? the tuf looks alot better
you wanted cheap. And, the Prime-P is cheap, without looking cheap and without serious cost cuttings, compromised performance... Low-end X570 on the Asus lineup, yes. But pretty decent& great value board
See the list
And also this table
suitable for 3900x OC-d.
Life is really challenging. I don't always suceed: )
