22 minutes ago, Adsome2007 said:
I have i Corsair sp120 rgb pro and it has 2 cables one which goes into the hub and another 3 pin cable what is the three pin cable for is it a 3 pin fan cable
looks like its  a non pwm fan so they used a 3 pin.
https://linustechtips.com/topic/1095887-sp120-rgb-pro/#findComment-12822802
