Hey guys . Greetings from germany. I hope that you guys can help me and im sorry for my bad englisch.
I just got the Ryzen 9 3900x . I got the 3600x before and the thermals were good. i got an Custom Waterloop with 2x 360mm Rads a quite decent pump an ocool waterblock for my 1080ti and the new hydro X Series waterblock for the cpu. i got the MSI MEG x570 Ace Motherboard and as RAM i got the Corsair Vengeance DDR4 3200 C16 2x16GB. The Watercooling loop is what i run for years beside the CPU and GPU Block. The flow for the loop is good too. Now heres the Problem. I assembeld everything and looked at my Ryzen Master Programm. and The Problem now is that even under a very very small load the temperature is going up very fast. i mean if i start chrome the temps go from 38 to 58 in just a second . if i run cinebench r15 at 3.8 ghz it maxes out at 95 degrees. i even tested that i just press the block down with my hands cause i thought it has like a gap or smth that the cooler doesnt reaches to the die. i even tested the air cooler that comes with it and a cooler master ml240 AIO cooler but there is no diffrence . the cpu goes to 109 degrees and then shuts down. at gaming the temps are around 60C, the GPU is just fine. even after 30 mins of Furmark the temps even with overclocking wont go over 40degrees C. What is suspicious to me is when i run r15 the PPT goes to 130% the TDC goes to 122% and the EDC goes to 90% without even touching the CPU so its on Stock settings i didnt touch the CPU Settings at all. i hope you can understand my problem and im hoping you guys can help me. Im sorry again for my bad englisch and if anything is dont understandable im trying my best to explain further . i did a Photo of my rig but removed the fans just so you can maybe see what is going on . Thanks for your help guys !
https://linustechtips.com/topic/1094665-ryzen-3900x-thermal-problems/
Crank up the pump speed?
Increase fan speed?
Check if flow is decent?
Check if the CPU has good contact with the block?
See if radiators are way too hot?
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
Temp jumps seem normal even if just using Chrome or something.. its just the way the new CPUs work.
My 3800x can be doing very little and all of a sudden the CPU usage will jump up and then the temp will go up as well. When AMD released their chip set driver they also had an article that explained this was normal even when using the AMD balanced windows power settings. Its because they wanted t the response times on the CPU to be really fast.
But that does not explain the really high temps :( its a strange one really it sounds like you have tried a few different types of coolers and you get the same issue. Maybe the AMD auto clock stuff is pushing the voltage to high you could always try manually setting that lower.. maybe someone can pop along with a better suggestion.. hope you get it sorted.
1 minute ago, LoneyMakkaroni said:
the strange thing @caldrin is that before i got the 3900x i got the 3600x and i ran it with the normal air cooler because the waterblock wasn´t here yet. the temps were normal :(
When gaming my 3800x usually sits around 65 to 75 sometimes spikes a bit higher.. not tried any synthetic benchmarks so unsure what kind of temps i would hit with those.. might give some a go tonight and see.
Running an NZXT x62 AIO..
Have you tried rotating your cold plate/water block?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
Welche Pumpe laufen Sie? Auf was ist Ihre Pumpendrehzahl eingestellt? Stellen Sie einen Spannungsoffset über 0,1 V ein und prüfen Sie, ob Ihre Temperatur sinkt. Versuchen Sie es mit Ihrem Block, damit das Logo unten ist. Die Mikrofinnen befinden sich nicht direkt über den Kernen.
I have the same waterblock (Corsair xc7) on my 3900x. 3 things to watch out for.
1) make sure you have thermal paste
2) make sure your block is screwed in tightly
3) this shouldn't make much of a difference, but Corsair recommends having the water flowing in on the right hole and out the left (based on the orientation of your pictures, water flowing in from bottom port and out the top port of the block)
print "Hello World!" ("Hello World!")
