Best Headset for around $50?
Vod
Hello!
I currently have a SADES SA 902 because the headset is bit, heavy and isn't that comfortable so I'd want to upgrade for around 50$
I see you're in Croatia, are you buying localy or importing from the US?
I was going to recommend an HyperX Cloud, but now i'm not so sure if will fit your budget.
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
I use ebay.de for my shopping needs
I have a pair of these (i am in USA, but I found the same ones for you on amazon.de, not sure if they are on ebay.de or not.) I have been very impressed with them, and the battery life is outstanding.
https://www.amazon.de/OneOdio-Bluetooth-Kopfhörer-abnehmbare-Spielzeit/dp/B07CNRRBXS/ref=sr_1_7?__mk_de_DE=ÅMÅŽÕÑ&crid=CSDTWSIDAN6L&keywords=oneodio&qid=1565882972&s=gateway&sprefix=oneodi%2Caps%2C246&sr=8-7
