Hey guys, I recently got a rtx 2060 paired with a ryzen 5 2600 that I use with the wraith cooler that comes with it. Played steep an hour ago and I thought these temps were hot. Aniway, my question is are these temps normal for my gpu and cpu ? Settings in game are ultra
https://linustechtips.com/topic/1093665-are-these-temps-normal/
How is 49C hot, for a CPU?
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/1093665-are-these-temps-normal/#findComment-12804836
As for the graphics card, yes, it's normal, depending on your cooler. 72C is perfectly acceptable.
https://linustechtips.com/topic/1093665-are-these-temps-normal/#findComment-12804838
Alright, because I'm a noob when it comes to temp and results on google we're all different. What are normal temps for those parts ?
https://linustechtips.com/topic/1093665-are-these-temps-normal/#findComment-12804841
Just make sure they don't going above 90 or 95. Your temps are completely normal. 80 might be a bit high for a cpu if you ever see that temp, but it's still fine if it gets that hot
i7-4790k | MSI Z97 GAMING-5 | Corsair Vengeance 16 GB | Samsung EVO-850 250GB SSD & WD blue 1 TB HDD | EVGA 1070 SC | Red NZXT H440 | Cooler Master G650W
https://linustechtips.com/topic/1093665-are-these-temps-normal/#findComment-12804868
