Okay to delete system reserved partition after MBR2GPT?
TheSungirl
I have converted my HDD to GPT/UEFI and still have the system reserved partition. By what I understand it is no longer used and can be safely deleted. Since the system no longer boots from it there is no point having it take up space anymore?
I wouldnt risk my system not booting up for just 350mbs. That could be recovery partition that windows keeps some files in.
As stated above, it's probably not safe to delete and is absolutely not worth deleting since you only gain 350MBs (especially since you have 1.5TB of storage).
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
AFAIK there isn't even any point in converting it to GPT in the first place, unless you are going to do a fresh install so it actually USES EFI boot.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Crap, Mira beat me to it.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Dual-boot,
triple-boot,
quad-boot,
splitting a Windows drive to easily erasable OS without touching a hidden partition or multiple file partitions.
short-stroking a drive.
It makes sense since MBR has a four partition limit and Windows caps it instantly.
Thanks for the info, I have just removed it's drive letter and will be leaving it as is. While it was showing in file explorer it showed up with just a 0kb text file "recovery.txt" there must be more inside it. Would there be any way of looking inside just to see what's in there?
You don't know what MBR2GPT is, isn't? :)
Apparently not, I completely missed the EFI partition in the pic. ?
