Ram speed on OEM motherboard
Solved by porina,
Generally OEM mobos will run at the fastest JEDEC speed supported by both CPU and ram. Most enthusiast ram don't have higher JEDEC speeds programmed in it beyond 2133 or 2400. Note JEDEC speeds are relatively high latency anyway.
If the ram speed will make a difference depends on the use case. Many things are not significantly affected. Some things are strongly affected, but these are relatively uncommon. Given there's little you can do about it, just run as is.
A long shot, you could try running Intel XTU and see what options it gives, but don't get your hopes up.
