Looking for a cheap air cooler to cool my R5 2600X. I have a budget of around £30. I was looking at the Cooler Master Hyper 212 Black Edition, as it seems to have good performance and looks good. The Cryorig H7 also looks like a good option.
Does anyone have experience with either of these, or other recommendations? I want to reduce temps/noise from the stock cooler and maybe do a little overclocking.
CPU: AMD Ryzen 5 2600X  |  Cooler: Cryorig H7  |  Motherboard: MSI B450 Mortar  |  Case: Fractal Design Meshify C Mini  |  RAM: 32GB DDR4 3000MHz  |  GPU: EVGA 1070ti Gaming (Kraken G12 Watercooled) |  PSU: Corsair TXM650  |  Storage: Samsung 860 EVO 500GB + WD Blue M.2 500GB  |  Network Card: Asus PCE-AC56  |  Monitor: Acer Nitro VG270U  |  Audio: Sennheiser HD6XX + Schiit Fulla 2
Laptop:
Lenovo s540:  CPU: AMD Ryzen 5 3500U  |  RAM: 8GB DDR4 2666MHz  |  GPU: AMD Radeon Vega 8  |  Storage: 256GB NVME SSD
https://linustechtips.com/topic/1090884-cheap-air-cooler/
i had a hyper 212 a long while back in an old ivy bridge build. performs very well, good value cooler.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1090884-cheap-air-cooler/#findComment-12783015
The Hyper 212 does not have AM4 socket support. An upgrade kit CAN be purchase, but I don't know the price of it.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/1090884-cheap-air-cooler/#findComment-12783033
The newer black edition does support AM4 though.
Laptop:
https://linustechtips.com/topic/1090884-cheap-air-cooler/#findComment-12783038
Didn't know, but now I do. It's just when people only say 'Hyper 212' it could literally be 4 different coolers.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/1090884-cheap-air-cooler/#findComment-12783041
Either would be fine. I'd go with whichever is cheaper or looks better.
https://linustechtips.com/topic/1090884-cheap-air-cooler/#findComment-12784174
Would you even consider this worthy considering the Wraith Spire is fairly silent even at high rpm?
I understand that cooling wise something like the H7/212BE are likely to outperform it but if you're not really gaining any improvement "sound wise" and boost clocks might like be just 50 to 100mhz higher one can only wonder if this is necessary at all given how OP seems to be on tight budget.
I'm not entirely sure how the Spire stacks up against those.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1090884-cheap-air-cooler/#findComment-12784246
There isn't more or less silent. Something is silent or it isn't and the Spire is far from silent. How much more pleasant a quieter cooler may be depends on your hearing.
The Hyper 212 Evo is already quieter than the Spire and the Hyper 212 BE and H7 are even better. The extra thermal headroom allows for lower fan speeds and lower noise.
https://youtu.be/VNjkDoYZYjU?t=272
https://youtu.be/lsmqplMjTdo?t=198
https://gnd-tech.com/2018/10/cooler-master-hyper-212-black-edition-review/
https://linustechtips.com/topic/1090884-cheap-air-cooler/#findComment-12784686
Mayhaps I just got too impressed with it when facing Intel's solution that I tend to overestimate it's 'low noise'...
Here on the office we have a couple of i5 7400 computers on stock Intel which are extremely loud and recently I built by my boss request two new computers but I decide to use the R5 2400G instead, in comparison they are virtually silent what amazed me.
Thank you for the insight.
Personal Desktop":
https://linustechtips.com/topic/1090884-cheap-air-cooler/#findComment-12784700
