I have this PSU from a pre built pc and wanted to know if i can add an rx 570 4gb. If not, please suggest another one(link from amazon).
CPU: R5 2400g
iGPU: Vega 11
Mobo: Gigabyte ga a320m s2h v2
Ram: 16gb (2x8) ddr4 2666mhz
Storage: 240gb SSD
Info on PSU: https://www.e-gate.gr/490623/force-500w-8cm-fan-psu-force-500
https://linustechtips.com/topic/1090316-help-in-choosing-psu/
3 minutes ago, Metallus97 said:
Wattage whise yes, but DONT! Its pretty crappy! You can get a decent PSU with wattage around 500W for like 60-70 bucks
Yeah, i knew that but just wanted to confirm. I think 450W is enough for my system. Can you suggest me something?
https://linustechtips.com/topic/1090316-help-in-choosing-psu/#findComment-12778478
1 hour ago, EL02 said:
I wanted something cheaper since 450w is enough.
Get a decent PSU with ample wattage - a bad unit can kill a whole system in an instant. Insufficient wattage will result in the PSU running hot and thus shortening its lifespan.
https://linustechtips.com/topic/1090316-help-in-choosing-psu/#findComment-12778651
1 hour ago, 5x5 said:
Corsair CX550M should be fine.
OP should get a CX not a CXM. I know modularity is nice. But the CX is Halfbrige and the CXM is Double forward wich is kinda crappy. Especially when pushing it!
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1090316-help-in-choosing-psu/#findComment-12778658
Correct, but considering OPs system of a 2400G and possibly an RX570 future upgrade it won't really matter.
If the Corsair CXM/CX is out of the budget then have a look at Be Quiet System Power 9 or Corsair VS450 (grey label)
The VS450 is available on that website you linked for 39 Euro. https://www.e-gate.gr/587595/corsair-vs450-450w-12cm-fan-80-white-cp-9020170-eu
https://linustechtips.com/topic/1090316-help-in-choosing-psu/#findComment-12779282
