Just finished up my new PC yesterday and today I finally managed to get some time gaming with it. I’ve seen a lot online about 2080ti running hot when gaming and just want to check to see if my temps are ok, in your opinions. When gaming, the gpu immediately ramps up to 70C. Literally within the first couple of minutes, over the rest of the gaming session it tends to fluctuate at around 73-80C. It’s an EVGA gtx 2080ti XC using the aggressive fan curve from precision X1. My cpu temps seem fine, it tends to be below 55C. What do you guys think? Are these ok? Thanks!
https://linustechtips.com/topic/1089975-2080ti-temps-when-gaming/
Just now, goto10 said:
that case is not the best in terms of airflow, it was better the meshify c, but you already have it
how did you set the fans in the front, top and back of the case?
I've got a h150i in the front as an intake, another 140mm fan as intake in the mid bottom of the case. A 140mm fan at the top as an exhaust along with a 140mm at the rear top as exhaust.
Good post goto10 my friend.  Let me note even 85c is great even 90c, then once you get close to 100c your playing with fire.  Also are you using any app to set a fan curve, perhaps your fans are not spinning fast enough ?
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Wow, really? 85C still nothing to worry about? I am using EVGA precision X1 with the aggressive fan curve.
I have a XC and I get about the same.
The XC will down clock at 84c so staying below that is my goal.
With the power target at 130% and an slight overclock mine is at about 84c under load. Since it has really good silicon I may water cool it.
Here it what it looks like.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
So when gaming your fan curve goes to 100 percent and your getting 80c is normal.  85c is ok as well.  But close to 90c could reduce the life span of the card and 100c is max,, that is boiling point and your really playing with fire and what not.
I see your fan is not spinning at 100 percent on this load you have given it ?  Take it to hundred percent my friend.  No wonder!!!  Also your 117mhz gpu overclock wont do diddley sh*T for your frame rate.  Only 200Mhz on VRAM ?  Only 200Mhz on the VRAM is a joke.  You should be able to go much much higher and not worry about things heating up and what not.
Temps are fine.  Do a bit more research next time when spending that kind of coin, since you're worried about it.   Under 80 is normal in that case especially when the AIO is in the front.
If you want, grab another 140mm fan and put it in the bottom as intake.  It's a quiet case, hence the solid front panel and sound insulating material all over.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
I definitely will do, should have done more this time, you're very right about that!
I've already got one 140mm at the bottom as intake, would you suggest adding another in then?
This is a daily overclock and it is too noise under load. I like peace and quiet.
The 117 is to keep the temps below 84c. Higher and the card will down clock a 100mhz.
Vram gets hotter than the GPU with these cards. The heat builds up over time and does not drop fast like the GPU, so I only use 1000+ in benches. It is the same with my FTW3 Ultra.
I misread your previous post reply, so you only have 2 exhaust fans and 4 intake...  Add another 140 as exhaust on top then, to get more air passing thru the case at a decent clip.
Either way, 80c is nothing to the 2080Ti really.  It's a fine temp for it.
OnePlus Ecosystem:
3D Printing:
Ok, I have a spare fan so I will go for that. I'll have 4 intake and 3 exhaust, you think that might help a bit?
