What happens if I use a 1080 and a 1060?
oLoGy
Hi, I have a 1080 GPU that I use in my PC, and an old 1060 that I don't use anymore, that I am going to sell in a few months but I can't right now. I thought it would look cool to put both the graphics cards into my PC.
I was wondering what would happen if I put the 1060 card into a lower slot and didn't connect it to the PSU while still using the 1080.
Probably just errors, worst case.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
U could connect it and use it as physx Card its pretty useless but having a dead card in the system for looks is too and if u connect it it atleast does give less errors haha
Either an error code, maybe a bsod.
as long as the power draw stays under the max a pcie slot can supply it will probably be fine.
You wont hurt your PC, just pop it in and find out first hand.
As far as i know if u dont connect it to the psu u cant even boot u get a black screen telling u to put in pci power in ^^
I hope there is an option to use that 1060 card as the render device for streaming, then your 1080 will be your main driver.
Ryzen 5 1600 | Gigabyte GA-AB350M-Gaming 3 | Team Elite TForce Delta RGB 2x8 16GB 3200mhz | Gigabyte GTX 1060 6GB AORUS | Fractal Design Arc Mini R2 | 2 1TB WD Blue | Wester Digital Blue 3D NAND 500GB | SeaSonic M12II 520W 80+ Bronze | CoolerMaster Hyper 212 Led Turbo | ASUS VG248QE | Rakk Kimat XT | Logitech G502 HERO | Massdrop x AKG M220 Pro | V8 Soundcard | BM800 Condenser Mic | Logitech C310
