Hello guys
Im new to this .
I have a question my pc that has a i7 8700k and a cooler master seidon 240v is getting HOT.
Yesterday it got up to 96°c is this normal for this set up?
please note my cpu isn't overclocked. Everything is stil stock.
thanks.
https://linustechtips.com/topic/1087526-to-hot/
2 minutes ago, Woutje101 said:
Hello guys
Im new to this .
thanks.
Check to see if you applied thermal compound, or if you accidentally left plastic cover over the cpu cooler.
If that isn't the case, are you sure the AiO's pump is working?
https://linustechtips.com/topic/1087526-to-hot/#findComment-12757002
Nope 96°C isn't normal. Under full load 80°C is about the max you want to see. Did you remember to put thermal paste on it? Was there a plastic film over the bottom of the cooler you may have forgotten to remove? Is the cooler properly screwed down?
https://linustechtips.com/topic/1087526-to-hot/#findComment-12757005
Im sorry to say this but I didn't put the computer together.
So I don't know if the right amount of thermal paste has been aplied or the plastic film wasn't removed.
https://linustechtips.com/topic/1087526-to-hot/#findComment-12757009
Regardless of who put together the computer you can check and correct this yourself you just need a screwdriver, fresh thermal paste and some isopropyl alcohol or isopropyl wipes and you'll be able to redo the thermal paste application.
Also how did you check that the pump is working?
https://linustechtips.com/topic/1087526-to-hot/#findComment-12757067
then you're gonna wanna get some thermal compound and put some on your cpu.
And while you're at it, exercise your pimp hand against the guy that did put the computer together.
https://linustechtips.com/topic/1087526-to-hot/#findComment-12757072
thanks for your help
When his store opens I wil be waiting to pratice the art of the pimp.
https://linustechtips.com/topic/1087526-to-hot/#findComment-12757082
I can check it but I don't have fresh thermal paste.
The pump is working becuase when I start up the pc I can hear it and also if I go in the bios it shows that the pump is working.
https://linustechtips.com/topic/1087526-to-hot/#findComment-12757083
Why not take the pc back to where it was built?! It sounds like they did no testing at all and those temps are thermal throttle temps already, that poor cpu is overheating nonstop.
If thats not an option, almost any decent pc repair shop will gladly give you free thermal paste if you bring your computer in.
But really those temps sounds like the cooler is not even touching the CPU at all or is totally incorrectly installed.
Lastly just order some on amazon or anything similar, thermal paste is pretty cheap.
https://linustechtips.com/topic/1087526-to-hot/#findComment-12759705
