Power Supply For 2080 ti
JB780
This may be a stupid question.
I have a Corsair RM750X and an Asus 2080ti that I am installing. Can I wire the GPU with 1 cable of the "daisy bridge" 2 x 8 connectors that came with the PSU or do I need to have two separate cables connected to the GPU and just tie the extra 8 pin connector on each back?
I've been trying to research this but I've been reading conflicting posts on if this is necessary or not and I'm not 100% sure on how the power supply functions with the daisy bridge cables.
On a PSU as good as the RMX, you can use a single cable.
Primary PC:
Even if I'm planning to OC it? Do you know if the same amount of power so be drawn through 1 cable as two?
Should be fine
Primary PC:
The difference between 2080 tis stock and overclocked is vast.
I got this off my two 2080 tis this morning. See image.
Without knowing the chip you have to take in to consideration that a 2080 ti can use from 260 to 373 watts under load. My FTW3 Ultra hit 387 watts this morning so the GPU-Z numbers are just estimates.
If you consider that the specs of the PCIE slot is 75 watts and the two 8 pin power connectors are rated for 150 watts each, some 2080 tis max that out and more.
It is easier for me to just use two cables than look it up but it would be interesting to know for sure.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
So if the 8 pin connectors can supply 150 watts each then there would be no benefit to using 2 separate cables because the limiting factor is each connector only being able to supply 150?
Unless they draw more than spec.
Nvidia puts 150 watts as a standard for the board partners but 300 watts is possible with an LN2 bios. Nvidia cards have a lot of power balancing hardware so the connectors keep close to even in power draw.
The board partners seem to cheat but not by much.
