Air cooling for a 3700x?
lillo9546
Hi guys ! Could . you reccomend me the most silent and effective cooler for a 3700x? And other options? Thanks
Since price is not mentioned, just get the Dark Rock Pro 4.
Desktop benching:
Total is 1000 euros with no monitor and pheripleas
I am a noctua fan always considered as best product. But years pass is this the new winner?
Same performance but in black instead of beige and poop. You can go with the D15 if you like
Desktop benching:
what about fan noise?
Same there two. Specifically Noctua has higher fan speeds and hence higher noise and performance when maxed out. At the same noise level they are the same.
Desktop benching:
Brilliant!
Do you know where i can find noise db level?
I will not use the amd stock cooler is bad imho..
So i go with this dark rock
Country?
1 minute ago, GoldenLag said:
Country?
Spaghetti Land
10 minutes ago, lillo9546 said:
Spaghetti Land
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (€377.99 @ Alternate Italia)
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard  (€114.19 @ Amazon Italia)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  (€77.98 @ Amazon Italia)
Storage: Patriot Scorch 512 GB M.2-2280 Solid State Drive  (€64.99 @ Amazon Italia)
Video Card: Gainward GeForce GTX 1660 6 GB Pegasus OC Video Card  (€230.00 @ Amazon Italia)
Case: Fractal Design Focus G ATX Mid Tower Case  (€50.27 @ Amazon Italia)
Power Supply: be quiet! Pure Power 11 CM 500 W 80+ Gold Certified Semi-modular ATX Power Supply  (€81.59 @ Amazon Italia)
Total: €997.01
Generated by PCPartPicker 2019-07-24 10:11 CEST+0200
Here you go
Total: €997.01
Here you go
For the ssd may i choose the SABRENT ROCKET?
Sure, i dont see why.
The sabrent isnt faster?
Regular NVME is allready plenty fast......
ha i mean 60 euros for the one u listed, with 20 euro more i can get 512gb 3500/2000 speeds i think its better for future
Not worth it. Spending that much extra is better spent on a properly cached drive
What do you mean? Sorry im a noob
SSDs have cache they write to so they can smooth out the writing process to the nand-flash. Not having it reduces random read and write performance.
You can look at specs and reviews. Audio clips are also good since tonality can make a big difference outside of dB levels.
https://www.hardocp.com/article/2018/05/24/be_quiet_dark_rock_pro_4_cpu_air_cooler_review/3
https://www.techpowerup.com/review/be-quiet-dark-rock-pro-4/7.html
http://tech-legend.com/reviews/be-quiet-dark-rock-pro-4/3/
https://www.techtesters.eu/be-quiet-dark-rock-pro-4-review/\
I'd recommend the similar but cheaper Le Grand Macho RT instead: https://it.pcpartpicker.com/product/B8rcCJ/thermalright-cpu-cooler-legrandmachort
