Ryzen 3600x memory OC problem
Go to solution Solved by Mathieu9836,
Only trying it will tell you, i know they removed 1.0.0.3ABA because it was worst then the AB version. The AB version still not stable and there is some voltage settings not working and major glitches, so yeah..... i don't know what you should do. Give it a try and if it's worst then reinstall the older BIOS update, thats what i was doing with my DS3H when i update the Bios to F30 and i was not having sound then they released F40B which was very unstable so i reverted to F4.
I was able to run my 3000mhz memory at 3200mhz with tighter timings on the DS3H, now it's on a Crosshair VII with the lastest BIOS with a 2nd gen Ryzen and i can't make it run at 3200mhz with very loose timings, so i will install an older BIOS update and see how it goes.
Hi all,
this is my first post on forum so welcome everyone :)
i'm having problems with RAM memory speeds on my new platform.
After enabling XMP, or changing memory speeds manually mobo is trying to boot up 3 times, and then posts with resetted bios settings. No post code in those 3 attemps. ( fans/rgb are up/down 3 times )
Weird thing is, this problem occurs only on cold power up. When i change bios settings hit 'save and reset', then pc is booting up normally with desired speeds.
Have not seen any stability issues when booted into windows - occt, games, programs ect runs without any problems.
I heard ryzen is picky about the ram, but what confuses me, is why its booting up and is stable later?
setup:
ryzen 3600x
aorus elite b450
Gskill 2x16GB 3200MHz CL16 [F4-3200C16D-32GVK]
aorus rtx 2060
aerocool 650W psg lux rgb
bios on mobo - F40
I'm wondering if i shall return RAM and get another set.
Thanks in advance !
https://linustechtips.com/topic/1085424-ryzen-3600x-memory-oc-problem/
Just now, Marh said:
Hi all,
setup:
ryzen 3600x
aorus elite b450
aorus rtx 2060
bios on mobo - F40
Thanks in advance !
I cant answer the WHY but I can tell you my 3600mhz RAM (With R7 1700) is only unstable on cold boot after a night with the PC off.  It will not post the first attempt, but will post after that and every time after that with zero stability issues (OC on CPU on or off doesn't matter)...until like 12 hours turned off then it exhibits this again.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
I have the same with my 1700, X370 Carbon and memory at 3200mhz. When i set the XMP profile to 2933 i have no issues.
And also like @Tristerin If i do clock them at 3200, when they are 'warm' they will function as normal.
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
Hi again,
update : ANY alteration to memory speeds other than mobo defined itself are giving same results.
i changed memory freq 1 tier lower than 2166 and same thing happened.
i'm starting to suspect faulty mobo or RAM.
i will cannibalize other pc for RAM and check if its same behaviour.
Wait for the new Agesa update, it's very unstable right now. Zen+ did the same thing but Zen2 seems to be worst, you guys need to realise YOU are the beta testers for Zen2 and there will be a couple updates before its stable as Zen+ was before the new CPU came in. Give it a couple months and you will see a huge improvement.
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
@Mathieu9836 you might be right - did put different ram stick ( 8GB iridium x 3000MHz ) and worked perfectly.
Other system has ryzen 2nd gen and G.skill are working there aswell on XMP 3200. funny thing is almost same mobo :) gigabyte b450 ds3h
so comatibility issue 100%
@Mathieu9836 there is new AGESA 1.0.0.3 AB bios on gigabyte site already - you think its worth updating bios?
