Hello everyone,
I'm in a bit of a dilemma here... So I'm 2 months away from building my first ever PC, a powerful one too. But I'm getting some sick ass anxiety. The PC has an RTX2080ti, I7 9700k, 32GB ofRAM, and where I live that's more expensive than NA (3600$ to be exact), and the warranty is a bit different too. If i break a part while building it, I'm royally screwed. But if i build it myself it's gonna be 140$ cheaper than what it would be if i select the parts and let the professionals do it, and I could buy a Samsung QVO 1TB SSD instead of a 2TB Seagate drive with that extra cash. But If i let them build it for me, the PC is not gonna have any problems because it's going to be built and tested by professionals, and anything that would happen to it is gonna be covered by the warranty since THEY'RE the one that built it not me. So I would like to know what's better... Peace of mind and virtually no risk of getting screwed over, or an extra 1TB SSD ?
P.S : I've watched NUMEROUS videos, and basically know everything there's to know about building a gaming computer. But the anxiety is not letting me do it.
Thanks in advance.
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/
4 minutes ago, Crypticc said:
Hello everyone,
Thanks in advance.
Build it yourself. I can guide you through it. It's very simple. Each part will have it's own warranty anyway so you're covered.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741165
Just now, Crypticc said:
Thanks for the offer, i appreciate it. It's just the anxiety of the risk of breaking something.
You would really have to be like 5 to break something.
Like what EXACTLY are you afraid of?
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741172
Of a lot of things, but the biggest one is putting the CPU in the socket the wrong way and bending a pin. I know the CPU has indicators and its really easy you just have to align stuff and drop it in. but still
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741181
6 minutes ago, Cora_Lie said:
Well... respect a few rules and everything will be fine ^o^
  • Be grounded!
  • Don't eat and drink next to your build
  • Take your time.
  • and the most important one : RTFM!
Thanks for the tips, ill be sure to follow them. Especially the last one
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741242
You can also find some very useful videos on Youtube with some good tips, like the "How to build a Gaming PC in 2019 - Part 1/2/3" on Paul's Hardware Youtube #
I really like that one.
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741258
I have that saved in my favorite in youtube, will be checking it out while building.
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741260
dont over think it, and just trust yourself.   its just like legos.
im betting the only problem you might have is the front panel connectors, and the instructions for that are in the motherboard manual.
just dont forget the io shield like i always do, and itll be smooth sailing.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741265
I think the motherboard i chose has a pre installed IO shield so thats a plus, just need to not accidentally drop the motherboard on the ground lol
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741281
ive done it.  turned out fine.
honestly the only things that will actually screw anything up, is bent pins(which can be unbent most of the time), or snapping off a capacitor or something like that, which isnt easy to do.
ive dropped motherboards, graphics cards, cpus, harddrives.  it all turned out fine.   being careful is good. being careful to the point of being scared, is a waste.
|Specs in profile|
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741290
For what its worth I hear ya, I did my first build solo back in October and dumped in more $$$ than you did. It can be a bit stressful but in reality the parts are actually fairly robust and durable, and the cpu thing I understand but in reality its actually super easy.
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741295
Thanks a lot, definitely will be building it myself since i now know that the part aren't easy to break.
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741342
Consider these two points:
  • You will appreciate the PC more if you've worked to build it. If you purchase a pre-built PC, you will be in possession of somebody else's work. Not your own. You won't be able to share stories of the building process. You won't feel that elation of overcoming a challenge.
  • In building the PC yourself, you will also learn how to build a PC more generally, what functions the components perform through direct observation, and how they interact to comprise a working computer. This skill cannot be purchased. It is more valuable than the computer itself, and it can only be acquired through experience.
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12741964
You have a very valid point, building a pc yourself is quite the experience and i wanna experience it fully. Also heard that booting a PC for the first time gives you the ultimate anxiety but when you see it post, it gives you the ultimate orgasm. Can't wait for that.
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12743003
I've dropped my pc cause I tilted it too far as I was trying to plug the io connectors in or trying to tighten a screw. Then I did it 3 more times to the same pc. Nothing went wrong. Also just look at Linus, he drops things that are more expensive than your entire build and all his stuff works for the video. These things aren't made of glass they can take a reasonable beating.
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12743039
THATS RIGHT LOL, Linus drops all the expensive shit and it still works lol
https://linustechtips.com/topic/1085264-first-pc-build-anxiety/#findComment-12746162
