So, I bought a sh!t tonne of holy panda's and I wanted to see if I can make an on button for my PC out of one of them, is there anything specific I need to do??? How do I do it, I wanted to replace the power on button in my Corsair 570X with a holy panda switch with an artisian keycap, it looks like the switch would fit in fully. I have seen mods on reddit of people doing this, so I know that it is possible and I wanted to know how to do it.
Thanks in advanced :)
idk tbh
https://linustechtips.com/topic/1084886-using-a-keyboard-switch-as-power-button/
In theory there is nothing needed special, as both a PC power switch and keyboard switch are a momentary closed circuit signal.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
So I should just be able hook up the front panel power switch to the switch??? I may just use some wire to test the  theory first because in ideal conditions I dont really want to destroy my Power switch for noting. Thanks for the help :)
idk tbh
Yep!
Useful threads:
Total: $1891.98
shouldnt need anything special. fit it up, wire it up and you are done
Builds:
