Is there any air cooler about 130mm height and can handle 250W TDP CPU ?
By
IWannaNEET
in Cooling
in Cooling
Solved by Mira Yurizaki,
1 minute ago, IWannaNEET said:At the top I have a a12*15.
And my side panel is also vented.
I can add a fan on D9L
So considering the airflow, which would you recommend?
Unless that vent covers the entire area where the heat sink would be, the D9L is a better option for airflow.
Featured Topics
eric_s ·
Posted in Power Supplies8 -
1
Silencix ·
Posted in Cases and Mods1 -
8
LambdaBird ·
Posted in General Discussion6 -
2
12
