Low fps on 1070ti
Solved by Princess Luna,
Well a single channel 8GB might be an issue indeed... but if you believe the GPU is under-performing where it used to run fine before it might just be a case of Drivers messing up.
DDU in safe mode and reinstall the latest drivers fresh new and give it a go, if all seems right then you can reapply your OC using preferably MSi Afterburner.
Featured Topics
ClumsyMonster244 ·
Posted in Troubleshooting1 -
VirusDumb ·
Posted in Looking For Group0 -
Gat Pelsinger ·
Posted in Linux, macOS and Everything Not-Windows2 -
3
Sai125943 ·
Posted in New Builds and Planning1 -
3
eric_s ·
Posted in Troubleshooting2 -
Bublito ·
Posted in Troubleshooting3 -
3
1
