Trying to get my ram to run at xmp profile but wont boot.
Memory is corsair lpx 3200mhz 32gig kit.
CPU is 3800x
Should I be manually up the voltage???
Motherboard is asus X570 Hero.
3800X, Corsiar 32gig 3200mhz LPX, Asus Hero X570. 2080ti black edition
https://linustechtips.com/topic/1081395-xmp-issues/
There is probably multiple XMP profiles, i asume you're trying to run it at 3200mhz.
Have you tried running it at 3ghz? (2933) see if it will boot?
I know mine won't run at 3200 but will run at 3ghz (i'm still on x370 tho so i have my explenation)
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
https://linustechtips.com/topic/1081395-xmp-issues/#findComment-12712589
i just chucked in 1.5V @ 3200mhz  to see if it would boot. no trouble.
the kit is rating 1.35V so its very weird..
but I am not really sure what voltage is too much.
Windows was having alot of trouble laggy and shit so doing fresh install now.
The xmp profile should automatically do the voltage right?
https://linustechtips.com/topic/1081395-xmp-issues/#findComment-12712594
it should yes, but my experience is that its a combination of mainboard and memory, not just the memory.
My knowledge is not good enough to explain properly . . .
https://linustechtips.com/topic/1081395-xmp-issues/#findComment-12712596
thank. i entered XMP profile and changed freq to 3000mhz and it runs perfectly.
So i assume i cant RMA my ram.
Seems like a bios issue if you also getting it???
https://linustechtips.com/topic/1081395-xmp-issues/#findComment-12712615
No not a bios issue, for me its the chipset combined with the speed. X370 is known to have some issues in that regard.
X570 should natively support it, so if your memory is rated at 3200 and it doesn't run at 3200, i would RMA it,
https://linustechtips.com/topic/1081395-xmp-issues/#findComment-12712629
Thank You for your help
https://linustechtips.com/topic/1081395-xmp-issues/#findComment-12712807
