Just now, Trilex said:
yea but then configuring settings like portforwading will have to be done on both routers
nope, just on the current router as the other device would be running as a switch only, not doing nat or any routing.
i just installed opensense and the screen is black. Guess my hardware to old.
Technology is NEVER easy :(
why do opensense, it won't help your wifi speeds, you need a faster access point and/or client to get better wifi speeds.
Are you running at 5g for wifi?
