I watched Anthony video of Manjaro OS and start using it. I found its good as compare to windows, fast and robust.
Mistakenly I was running random commands and I ran this one chmod 0664 /* and now I am unable to boot.
Any solution?
Just starting out my things.
https://linustechtips.com/topic/1079154-manjaro-issue/
Any solution?
Well you simply fucked up severely. Sure there are fixes to get it to boot but many commands will not work. Only real fix is to reinstall Manjaro. What you basically did was modify permissions for the root folder which almost always kills a PC no matter the permissions. You have it set to read write.
1 minute ago, Electronics Wizardy said:
restore backups?
You probably can restore permissions to where they need to be, but its gonna be a pain.
And you can change the permissions if you spend days working on a fix. It is "possible" but not practical in any sense as it has a high chance of not working, and if it does, stuff like Sudo will shut down as a similar command I ran when I first used Linux basically shut down Sudo and I could not fix it.
TL;DR:
Reinstalling is the better option (from experience)
https://linustechtips.com/topic/1079154-manjaro-issue/#findComment-12695788
2 minutes ago, emilie said:
Don't have any backup and I was using standard notes on it. I have like few hundreds notes their. Any auto fix script for permissions?
do you want these files, should be able to easy copy the files off of it and reinstall.
https://linustechtips.com/topic/1079154-manjaro-issue/#findComment-12695793
TL;DR:
If I reinstall my notes get delete and I have seed and private key of my atomic wallet.
https://linustechtips.com/topic/1079154-manjaro-issue/#findComment-12695794
Yes I want but the issue is; I set the passcode lock on it. What I did to get these notes is; boot into live manjaro (USB) and browser the drive with /home/ location and found standard notes files but they are not readable as I think these are encrypted.
https://linustechtips.com/topic/1079154-manjaro-issue/#findComment-12695797
id try copying these notes to anouther system, its probably not tied to that system if you know the password.
https://linustechtips.com/topic/1079154-manjaro-issue/#findComment-12695799
Well you have two options:
1. Accept the fact they are most likely gone
or
2. Be me, a stubborn bitch and do the 10 step program of pain
  1. Duel boot with another OS
  2. Get the IMG file of the partition of your first Manjaro install
  3. Look through the data
  4. Copy your files
  5. Look through them
  6. Get rid of the corrupted ones
  7. Backup everything to Google Drive (LIKE YOU ALWAYS SHOULD)
  8. Recreate the files you lost to corruption
  9. Cry
  10. Calm down and back those new ones up too
If they are encrypted there are many decryption tools.
Good luck
https://linustechtips.com/topic/1079154-manjaro-issue/#findComment-12695801
Yes I know the password and tried to restore at different system but nothing come up in standard note.
https://linustechtips.com/topic/1079154-manjaro-issue/#findComment-12695802
or
  4. Copy your files
  9. Cry
Good luck
Sounds like a lot of work for newbie but its worth a try to get coins back.
Edited by emilie
mistake
https://linustechtips.com/topic/1079154-manjaro-issue/#findComment-12695803
Any solution?
Reinstall. This is pretty much impossible to fix. Why would you run that?
Your important data isn't necessarily lost, you can copy it out if you boot from a live disc - what software did you use to encrypt your files?
Also, always make a backup of important documents like this, especially if you're going to run random commands on your operating system...
sudo chmod -R 000 /*
https://linustechtips.com/topic/1079154-manjaro-issue/#findComment-12695999
