A couple days ago, my cat pissed on my computer. Sadly, I did not do a thorough rinsing of the motherboard and it causes a part of the pcb lane near the ram slot to bust.
Resultantly, I was forced to upgrade to an Asus z390i and a 8600k. (yes, I know Ryzen 3000 series is almost here... and the new intel  ..but I need a new computer asap.)  Now my here is my question, which ddr4 ram do you recommend?
This is really tricky because I heard that the true speed of the ram is MHZ/ CAS latency.
As such, some 3200/3600 are actually faster than their overpriced 4000+ models with very relaxed timing.
So here are my questions:
1) Is my understanding of true ram speed correct?
true ram speed = MHZ/ CAS latency
2) Please recommend me a ram for gaming. I do very little editing.
For instance, I've notice that beyond 3200mhz, there is only insignificant gain in FPS that cannot justify its extra $100  price tag.
Also, the ram needs to be compatible with my asus strix 390i and nh-u14s cooler.
Thanks in advanced!
CPU: 8600k @4.9  (1.39v) |  Cooler: NH-U14s | Mobo: Asus Strix z390i | Ram: Gskill DDR4 Trident Z 3600 8GB x 2 16-16-16-36
GPU: Gigabyte G1 1080 GTX | Case: Prodigy ITX | Fans: NH-A14, (exhaust) NH-A12, (intake) NH-A20 (intake)
Samsung EVO 1tb | Samsung EVO 512gb x2 | Intel ssd 128gb
PSU: Powerstation 500W
https://linustechtips.com/topic/1073519-need-recommendation-for-ddr4/
T-Force Vulcan 3200Mhz is usually best value at about $75-80ish
G.Skill Ripjaws V is another option, also pretty cheap at sub-$90
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
You're pretty much right on the true speed of RAM, Its usually a good mix of high clocks and low timing. I would say for Ryzen though your RAM clock is going to have a bigger difference than your timings. That being said RAM that's always good to go with is Corsair Dominator sticks, if you can fit the bill that is, they usually are a little on the pricey side.
Rainbow Barf
CPU: i7-12700K GPU: RX 6800 XT RAM: 64GB DDR4 Storage: 2TB NVME SSD RAID - 1TBx2 NVME SSD - 8TB HDD
Lenovo Legion Pro 5i
CPU: i7-12700H GPU: RTX 3070 Ti RAM: 32GB DDR5 Storage: 1TB + 1TB SSDs
for intel i'd go for any 3000/3200 kit with a good price, however if you are in the US, i'd buy gskill for the warranty (they actually ship out new sticks)
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
