6 minutes ago, GoldenLag said:
Looks normal to me.
Unless the CPU is thermal throttling at 100*C
The CPU is very cold, would you recomend me to turn down the fan speed and just let the AIO work with a higher temp? because the noise is driving me crazy
Water temps doesnt matter.......
CPU temps does. Water temps are irrelevant in comparison to CPU temps
On 6/16/2019 at 4:42 AM, LifeLight said:
But when do the water temps get dangerous for the AIO
On 6/16/2019 at 4:43 AM, GoldenLag said:
When it starts boiling. Which is never.
Actually, there's a chance of fluid permeation through the tubes if the fluid temperature gets to around 60°C.
in other words. another reason not to get an AIO.
also, a good AIO should be built to avoid that.
Lots of watercooling pumps are only rated up to 60°C, in other words, another reason not to get watercooling :D
PC: Screw day theme users, I guess ¯\_(ツ)_/¯
CPU: R9 3900X @ 4.375GHz All Core MoBo: ASRock X470 Taichi RAM: 2x16GB Mushkin Redline @ 3200MHz 16-18-18-36 GPU: GTX 1080TI FE @ 2088MHz Cooling: Single 60x360mm rad w/ Scythe Kaze Flex, dual 45x540mm external rads passive, Nickel Plexi EKWB blocks, Alphacool VPP755V3 + Watercool Heatkiller Tube 250, Aquacomputer Quadro Case: Inter-Tech 4U 4129-N PSU: Corsair RM1000x Storage: 1TB Samsung 980 M2 SSD, 1TB Seagate Barracuda  Q1 SSD Network: Mellanox ConnectX-3 10G
NAS & Proxmox:
CPU:  Epyc 7302 MoBo: Supermicro H11SSL-i RAM:  8x32GB @ 2666MHz Samsung Registered ECC  Cooling: Enermax Liqtech TR4 II 360 w/ Corsair ML120 Case: InterTech 4F28 PSU: Seasonic Focus PX-650 Storage: 8x6TB HGST + 2x1TB WD Blue SN570 + 2x16GB Intel Optane SSDs Network: Mellanox ConnectX-3 10G
ML-Compute Server:
CPU:  i5 10600K MoBo: MSI MPG Z490 Gaming Plus RAM: 4x8GB HyperX Fury @ 2133MHz8 GPU: Gainward GTX 1080TI Golden Sample Cooling: Single 30 Case: RackMax 2U 8-Bay Storage Case Storage: 512GB Patriot P300 + 4x2TB Seagate Ironwolf NAS Network: Intel Quad 1G
Laptop: Acer Travelmate B117 (absolutely low power, but 12h battery life :D)
Phone: Oneplus Nord
Peripherals:
Monitor: LG 34UC79G + 27GL63T Keyboard: KBDFans 65Rev2 Mouse: Logitech G603 Mousepad: Cheap-ass GMB Mouspad Headphones: AKG K7XX  Other stuff: Novation Launchpad MK2, Aune T1 USB DAC/Amp, Behringer UMC202HD + Audio Technica AT2020 Condenser Mic
Cameras:
DSLR: Canon EOS 600D (Magic Lantern OS) Action Cam: GoPro Hero 3 Silver
Mountainbike:
Frame: Banshee Legend MKIII Fork: Marzocchi 380 C2R2 Titanium Rear shock: Rock Shox Vivid Air/Coil (switched depending on how I feel) Wheels: Spank Spike Race 33 Tires: Maxxis Minion DHR2/DHF Brakes: Magura MT5 Calipers with Shimano XT Levers Deraileur: Shimano Zee, Casette reduced to 6 Speed Crankset: Truvativ Descendant + 38T FSA Chainring Wheight: 16.4kg w/o pedals
