My setup is linked below.
 I feel the GPU may become a bottle neck for the CPU but wanted to conform if correct.
https://pcpartpicker.com/list/3mzfNQ
The ram is the two different options that is why it has two brands
I have case and all storage already.
The GPU I currently have is a (Pny- Gtx 660 2048mb Performance edition)
https://linustechtips.com/topic/1073059-is-there-problems-with-this-setup/
Why on earth are you running odd numbered number of sticks and non-identical sticks?
And your mobo is pretty bad.
I would look at getting a new GPU after sorting out the Ram situation.
PSU works but id look at changing it
Swapped the PSU and memory around, I know you mentioned not being sure but dual-channel and fast memory both improve Ryzen performance a good bit
PCPartPicker Part List
Type Item Price
CPU AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor $83.99 @ Amazon
Motherboard Gigabyte - B450M DS3H Micro ATX AM4 Motherboard $71.88 @ OutletPC
Memory GeIL - EVO SPEAR 16 GB (2 x 8 GB) DDR4-3000 Memory $64.99 @ Newegg
Video Card PNY - GeForce GTX 660 2 GB Video Card
Power Supply Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply $41.89 @ OutletPC
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $292.75
  Mail-in rebates -$30.00
  Total $262.75
  Generated by PCPartPicker 2019-06-15 13:44 EDT-0400
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
Just now, GoldenLag said:
Doesnt actually save clst considering the price of the B450 pro4. The minimum B450 bord one should get.
This ryzen apu was originally launched for the b350 mobo,tho. So if he can save cost to get a dual channel 16gb kit it is better.
The ram is two choices one or the other I would be going with not all 3.
depending on budget I was going to either go with 8gb or 16gb
Except it doesnt save money....
The B450 Pro4 is the second cheapest board only beaten by 1 board that shouldnt be bought.
Og so you are looking at a CPU, mobo ram combo?
CPU: AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor  ($109.99 @ Amazon)
Motherboard: ASRock - B450M Pro4-F Micro ATX AM4 Motherboard  ($68.99 @ SuperBiiz)
Memory: OLOy - 16 GB (2 x 8 GB) DDR4-3000 Memory  ($61.99 @ Newegg)
Total: $240.97
Generated by PCPartPicker 2019-06-15 13:50 EDT-0400
Save up for this.
The B450 Pro4 is the second cheapest board only beaten by 1 board that should be bought.
Ok then if it does not save money he shouldnt buyh a b350.I just said that if he was able to buy a b350 and save cost then it would be better to that than getting a b450 for more.
Except it wasn't launched for B350. There is still a chance you'll be a 300 series chipset board without the needed BIOS to run the 2200G or 2400G chips because it was launched with the 400 series chipsets with the option to backport to 300 series chipsets with a BIOS update.
Prior Build Log/PC:
Not really........ B450 has much better build quality. Not to mention BIOS support. And also you need to get a good board. Not cheap crap. Paying 5-10$ extra for that is well worth it. Not that you need to.
Type Item Price
  Total $262.75
The ram is a much better deal but should the psu just be less Watts?
because the original was cheaper for more wattage
You want a good PSU not a "meh" one. While the VS PSU is fine, its not something to choose over the CX550 (2017)
Same goes for the other components.
I suggest going for the components i suggested earlier. Including the PSU.
Type Item Price
Motherboard ASRock - B450M PRO4 Micro ATX AM4 Motherboard $75.61 @ OutletPC
Power Supply Corsair - CX (2017) 550 W 80+ Bronze Certified ATX Power Supply $49.99 @ Newegg
  Total (before mail-in rebates) $309.58
  Mail-in rebates -$35.00
  Total $274.58
  Generated by PCPartPicker 2019-06-15 14:08 EDT-0400
So all together this is what should be better like you suggested or am I forgetting something?
This looks good. While ome wants to save on components. Its good to get advice to get what is cheap and good so that it doesnt come back to bite you in the ass.
