I'm looking for a decent fan controller. With the sun beating down on my room all day it gets hot. I have posted the fans that I'm gonna get and the case I have. I'm still deciding if I want 3 x 120mm or 2 x 140 in front and top. I will be replacing the Phanteks 140mm in the rear. I'm not worried about noise. This may seem a little overkill.
https://www.newegg.ca/p/N82E16835608052
https://www.newegg.ca/noctua-nf-a14-ippc-3000-pwm-case-fan/p/N82E16835608048
https://www.newegg.ca/brushed-black-phanteks-enthoo-pro-m-atx-mid-tower/p/N82E16811854042?item=N82E16811854042l
https://linustechtips.com/topic/1072373-looking-for-a-decent-fan-controller/
Phanteks makes a solid little PWM hub, should fit perfectly fine on the backside of your motherboard tray
https://www.amazon.com/Phanteks-PWM-Fan-Controller-PH-PWHUB_01/dp/B00M0R05WE
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
Even in most hot summer and very cold winter, temperatures in normal flat where normal people lives are similar (unless you're living in Siberia and -10 Celsius is very hot for you). You don't really need a helicopter. Two fans are enough for airflow. More you need if you're person who build your computer in circus style (lot of lights, fans and disco ball inside). Otherwise - as I said, two regular fans will be enough (with proper BIOS settings).
I have 3 fans in my case already. 2 of them are Phanteks that came with the case and 1 is a spare Corsair fan I had for my H100i. All 3 are full speed and having trouble keeping up. On idle, the inside of my case is 50 degrees. I actually had my computer shut down 2 days ago due to the CPU getting way to hot. This was on idle. I hate lights on PCs, hence why i'm going with Noctua fans.
What are your specs and load temps?
Where are you reading idle temps?
