Hello, everyone,
I apologize for the trivial question, but I am just starting to understand the main differences between 2.0/2.1 and 5.1 audio systems.
However, I do not understand why when I change the settings on netflix/dvd from 2.0 to 5.1 it seems to me that the 5.1 has a higher quality. I only use a laptop or TV, without external speakers!
Thank you!
https://linustechtips.com/topic/1072061-audio-20-51/
2.0 - Two speakers (Left, Right)
2.1 - Two speakers (Left, Right), 1 subwoofer
5.1 - Five Speakers (Front Left, Front Center, Front Right, Back Left, Back Right), 1 subwoofer
7.1 - Seven Speakers (Front Left, Front Center, Front Right, Center Left, Center Right, Back Left, Back Right), 1 subwoofer
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
42U Server Rack: ISP Modem + UDM-SE + APC 3kVA UPS + 3x Dell Precision 5820 + TBD
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
https://linustechtips.com/topic/1072061-audio-20-51/#findComment-12639128
16 minutes ago, Lorcan said:
Hello, everyone,
Thank you!
Like many things, such as Gold or Plantinum ratings on PSU's, 2 channel or 5.1 channel audio has nothing to do with quality.  You may get a change in sound quality to your ears as the other channels are not being used.  If you force a 5.1 sound thru a TV, you'll only hear the channels the TV is capable of producing.  You won't hear the rear or subwoofer channels for example.  This may seem to give more clarity as the TV's shit speakers are producing less complex sound, now that the other sounds are separated out.
Ie.  The 2 speakers in a TV (assuming it has 2) now gets only the front 2 channels instead of the entire sound spectrum that 2.0 stereo would cause.
Think of it kind of like taking a pile of rocks and splitting it into 5 smaller piles, then only having to carry 2 of those piles in your hands.  Now take that same original pile and split it into only 2 piles and try to carry that.  First scenario is easier/lighter.  Kind of like for the speakers.  TV/laptop speakers are terrible usually and can sound bad when trying to play a full range of home theatre or music.  But give them a lot less to produce, they can do a little better hence seemingly clearer/better sound.
Edit: I probably explained it badly, hopefully someone with more audio knowledge can clarify for you.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1072061-audio-20-51/#findComment-12639132
Thank you! It was actually very clear!
So when I use the 5.1 on my laptop I am basically "lose" some channel, thus I hear more clearly the others?
https://linustechtips.com/topic/1072061-audio-20-51/#findComment-12639413
Yes, basically, due to the quality of the speakers in the laptop.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1072061-audio-20-51/#findComment-12639421
2 hours ago, Lorcan said:
Hello, everyone,
Thank you!
The 5.1 will seem to have higher quality as all the effects that are usually on the front channels in a 2.0 get sent to the rear channels, but seen as it is just a 2.0 setup you only hear the front two channels, it basically removes the effects from the front two channels so it lets the drivers react to other sounds/noises much better, this is why a surround system generally always has a subwoofer, as the surround channels do not have to play low bass frequencies (the speakers generally dont play below about 80hz with a sub in the system)
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
https://linustechtips.com/topic/1072061-audio-20-51/#findComment-12639506
I think there is no meaningful difference between the two in your case. The 5.1 will be converted to 2.0 by the operating system or the audio driver or the player. Usually this ultimately decreases the overall volume, but sometimes the software throws caution to the wind and increases the volume. People tend to always like the louder one.
https://linustechtips.com/topic/1072061-audio-20-51/#findComment-12640257
Actually it depends. Sometimes you do have "better" sound with 5.1 tracks, even if you're using a stereo setup.
If a source have two formats, let's say 2.0 and 5.1 in this case, the creators have two ways to do it.
  1. Make the 5.1 tracks first, and downmix them into 2.0 tracks. In this case, the rear channels channels are mixed into the front channels.
  2. Make the 5.1 tracks first, and make the 2.0 tracks seperately.
Obviously, the first way will sound different (but is it better? depends on yourself) than the second way. But you won't know which way will be chosen by them.
When your computer plays 5.1 track in a stereo setup, actually you can also choose these two ways in your player's settings. I'm not sure which way does these streaming websites' player do, but I guess the reason you feel the "better" sound is because that you're watching a content made in the 2nd way, and when you choose 5.1 tracks, your computer can only choose the 1st way instead, so now you can hear a different sound.
BTW, if you use the 2 front channels from 5.1 tracks directly as stereo output, you won't hear any conversations from your content, since all the vocal are in the center channel. Also since the low frequency sounds are extracted into the .1 track (LFE Low-Frequency Effects channel, for subwoofer), so you'll lose these sounds, depends on how much bass did the creator of contents seperated from other channels.
For local videos, you can install a PotPlayer in your PC, and there are a lot of options about the way it can handle these tracks. Switch these options and hear the difference might be really interesting.
https://linustechtips.com/topic/1072061-audio-20-51/#findComment-12642476
