Upgrade path for RX 580 8gb
HP24
I'm thinking of getting a new graphics card, i currently have an RX 580 8gb and im wondering what would be a worth while upgrade for me, im willing to spend about 220, thanks.
4 minutes ago, harryp2404 said:
-snip-
What are your full specs?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z690 Aorus Elite AX DDR4 | GPU - ASUS TUF Gaming OC RTX 4090 RAM - Corsair Vengeance Pro RGB 64GB 3600mhz | AIO - H150i Pro XT | PSU - Corsair RM1000X | Case - Phanteks P500A Digital - White | Storage - Samsung 970 Pro M.2 NVME SSD 512GB / Sabrent Rocket 1TB Nvme / Samsung 860 Evo Pro 500GB / Samsung 970 EVO Plus 2tb Nvme / Samsung 870 QVO 4TB  |
TV Streaming PC: Intel Nuc CPU - i7 8th Gen | RAM - 16GB DDR4 2666mhz | Storage - 256GB WD Black M.2 NVME SSD |
Phone: Samsung Galaxy Z Fold 4 - Phantom Black 512GB |
He can use another 8GB of RAM too.
System
  • CPU
    Ryzen 5 2600
  • Motherboard
    gigabyte b450
  • RAM
    8GB 3000MHz
  • GPU
    RX580 8GB
  • Case
    coolermaster lite box 3.0
  • Storage
    120gb kingston ssd and 7200rpm 1tb seagate hardrive
  • PSU
    450w semi modular psu
  • Display(s)
    MSI optix MAG24C 144hz monitor
  • Cooling
    basically none :(
  • Keyboard
    AUKEY keyboard (not sure which one)
  • Mouse
    corsair harpoon rgb
  • Sound
    HyperX cloud 2
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
None right now for only $220. The best GPU you can get for that much is the GTX 1660, and that GPU isn't going to be that much faster than your RX 580. At least not fast enough to justify dropping $220.
What you could do is sell the RX 580 and increase your budget by $100. If you do that, you'll have options like the RTX 2060. You'll have access to RTX features like raytracing, and you'll also have much better performance.
Looking at those specs, I'd also consider getting another 8 GB of RAM so you have 16 GB. Doing that might be more worthwhile than upgrading your GPU right now.
Edited by Kavawuvi
fixed a typo
Honestly with your budget there's not much you can upgrade to that would make a tremendous difference, like @jstudrawa said you could use another 8GB of Ram, but as for the GPU you already have an 8GB 580, anything that would be worth upgrading to from that is going to be quite a bit over your budget. If I were you I'd upgrade the Ram and wait for the new Navi GPUs to come out in the next month or two and save up for one of those. The 3080XT is supposedly RTX 2080 performance for $350.
For 220 you don't have a lot of option in the new catalog that will be better.
You can have a 1660, but only slightly better.
In the used market you can get 1070 and up or vega 56 on the red side.
Lower than that not worth it.
I suggest hodl for a moment till a budget Navi solution or sell the 580.
I hope you have that 8gb ram as 2x4gb dual channel though..
for 220, there is hardly better option. Sometimes Vega56 can be fetched for 240-250USD (at least in my location.). Perhaps you should stretch the budget a little?
Life is really challenging. I don't always suceed: )
I only saw specs for the rx5700 and rx5700XT, which are the 2060 and 2070 equiv.
Is this 3080XT an Nvidia card?
Also, if the OP is staying 1080p, no need to upgrade,.  Maybe if you move up to 1440p (UW even) then look at a new GPU for that reso.
OnePlus:
Other Tech:
 I saw a couple articles and videos about it a month ago could of just been fake leaks or something but they were pretty reputable sources.
Found them nevermind it's not 2080 performance it's 2070 performance for $340.
Most of what I read was leaks or rumors but I was pretty sure the price point and expected performance was confirmed by AMD.
https://www.techpowerup.com/255221/amd-radeon-rx-3080-xt-navi-to-challenge-rtx-2070-at-usd-330
https://www.techspot.com/news/79970-amd-navi-based-rx-3080-xt-rumored-offer.html
These graphics cards do not exist.
AMD officially announced Navi yesterday and the cards will be the RX 5700 and RX 5700XT.
The RTX 2070 competitor will be $449.
As for the OP and as a fellow RX 580 8GB owner, really the lowest priced worthwhile upgrades would be to a Vega 56 or RTX 2060 in the $300-$350 range for now.
I personally am waiting for Navi to hit the market and see what the performance numbers look like. I plan to probably edge into the RTX 2070 / RX 5700 XT territory to get a real upgrade.
Desktop:
AMD Ryzen 7 @ 3.9ghz 1.35v w/ Noctua NH-D15 SE AM4 Edition
ASUS STRIX X370-F GAMING Motherboard
ASUS STRIX Radeon RX 5700XT
Corsair Vengeance LPX 16GB (2x 8GB) DDR4 3200
Samsung 960 EVO 500GB NVME
2x4TB Seagate Barracuda HDDs
Corsair RM850X
Be Quiet Silent Base 800
Elgato HD60 Pro
Sceptre C305B-200UN Ultra Wide 2560x1080 200hz Monitor
Logitech G910 Orion Spectrum Keyboard
Logitech G903 Mouse
Oculus Rift CV1 w/ 3 Sensors + Earphones
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
Crucial Ballistix Sport LT 16GB (2x 8GB) DDR4 2666
Geforce GTX 1050ti 4GB
Intel 600p 256GB NVME
Seagate Firecuda 2TB SSHD
Logitech G502 Proteus Spectrum
