Just now, Origami Cactus said:
Look at the cooler.
Is the fan even spinning?
If you can get someone to remount your cooler with new thermal compound,
or replace it if the fan doesn't spin.
This,
also can you give us your full specs?
sudo chmod -R 000 /*
https://linustechtips.com/topic/1071708-cpu-temperature/#findComment-12636044
1 hour ago, Shubi said:
Hey i just came to know that my cpu is having some serious problem. My pc keeps shutting down unexpectedly many times. then i checked my cpu temp and that was 90-110o C idle. What should i do if  anyone is having any solution share it with me. Thanks
CPU cooler is at fault, possibly installed incorrectly, or if it's an AIO then it's also possible that the pump is dead
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1071708-cpu-temperature/#findComment-12636125
On 6/11/2019 at 3:01 PM, Origami Cactus said:
Look at the cooler.
Yesterday I opened that cpu fan and i found that the thermal paste is dried and it was like hard putty.  What should i do .
Actually i have very old pc like 13yrs old
amd sempron 1 gb ram 160gb
https://linustechtips.com/topic/1071708-cpu-temperature/#findComment-12641163
2 minutes ago, Shubi said:
160gb
On 6/11/2019 at 4:07 PM, starcoaster said:
if it's at that temp on idle then it's either a dead pump in the case of it being an AIO or no thermal compound. idle temps, even on a bad mount, aren't THAT high unless it's not making contact at all. 50-60c idle yeah but 90-110 is well in the territory of no heat dissipation at all.
https://linustechtips.com/topic/1071708-cpu-temperature/#findComment-12641171
Has the thermal paste even been replaced in the last couple of years?
Otherwise you might need either alcohol swabs (for easiest cleaning) or a wet tissue paper and a lot of patience to clean the dried up stuff off the heatsink & CPU then reapply a new layer of thermal paste.
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1071708-cpu-temperature/#findComment-12641722
Replace it. Clean it off with alcohol and apply some new thermal paste. Don't put too much in or it will make a mess - the drop should be about as large as 2 grains of rice
https://linustechtips.com/topic/1071708-cpu-temperature/#findComment-12641897
clean it off the CPU and cooler with rubbing alcohol and replay a grain sized amount of new thermal paste to CPU
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
https://linustechtips.com/topic/1071708-cpu-temperature/#findComment-12641941
