Need high-airflow case
Solved by Biggerboot,
6 minutes ago, Lord Mirdalan said:Yes, these are for GPU rendering. Not 24/7, but possibly days at a stretch.
And we might have a winner - that's a fine-looking case.
Cool.
Here's Steve's review on it:
I think the downsides of this case won't apply to you if you're doing a custom loop. It does have an 'air' version as well, but it's not beneficial in this case.
