Thermaltake Versa H17
Whiro
Hi all. So I’m looking for some small case for my build ( i5 2400, HD 7770 ) which I can hide behind TV, currently I own NZXT Phantom 240 which is way too big for me and taking too much space. I was thinking about Thermaltake Versa H17 , it’s small, cheap and supports 140mm fans (have few of them laying around), but the airflow seems a bit restricted , did anyone here own this case and can tell me anything about it?? Thx
   @Whiro tag or quote will do the trick
i5 3570K @ 4.7Ghz  |  AsRock Fatal1ty Z77 Performance  |  Corsair Vengeance 16GB 1600MHz  |  ASUS Strix GTX 970 OC  |  Phanteks P400S TG  (mesh panel) |  EVGA 500W1  |  Storage: Corsair 60GB SSD (boot), Gigabyte 120GB SSD, WD 2Tb HDD | Cooling: Custom loop
                EKWB EK-XRES 140 Revo D5 RGB PWM
                EKWB EK Supremacy Evo , naked die
                EKWB EK Thermosphere
                EKWB EK CoolStream PE 360
                EKWB EK Coolstream SE 120
                EKWB EK Vardar 120s  x6
                EKWB EK STC Classic 10/16  x10
                EKWB EK DuraClear Tubing 16/10
                EKWB EK CryoFuel Acid Green
Laptop: Gigabyte G5-KC | i5 10500H | RTX 3060
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
I used the H18 in Blue Build 2018 (signature) and the airflow was excellent. The case isnt exactly what I would consider "tiny" but its definitely a lot smaller than the Phantom 240
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
H18 have mesh front panel but H17 have mostly covered panel with small holes on the sides that is why I was wondering about airflow on that case.
                                          WHIRO
-SNIP-
For an i5 2400 and an HD7770, it shouldnt be absolutely terrible to keep from thermal throttling, especially if your 140mm fans are static pressure optimized.
