so im planning to build a budget gaming pc around 400$-ish
but im missing some part which is MOBO and PSU. for the mobo i really want to be futureproof AM4. quad channel really helps. if its not then its ok.
R3 2200g.................98$
KLEVV SSD 240g...30$
KLevv 4x2Ram........56$
rx570 4gb................147$
Case ......................30$
total 361$.  i can go maximum to 490$. can u help me find mobo and Psu?
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1069108-help-build-pc/
What form factor is the case
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614069
PCPartPicker Part List
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Power Supply: Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply  ($39.89 @ OutletPC)
Total: $99.88
Generated by PCPartPicker 2019-06-02 01:57 EDT-0400
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614086
Total: $99.88
its that the best mobo for that price?
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614091
Yes.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614095
Think you can stretch the budget just a little more, like an extra $50? You can fit in a 6 core Ryzen 1600 CPU, 2x8GB (16GB) RAM as well as an RX 580 8GB.
(Case not included, so add $30 to that price)
If you can't extend your budget then you should be able to bring the cost down within your budget by swapping the RX 580 for a RX 570.
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614114
3 minutes ago, Wolfycapt said:
5 1600 its 164$ here lol
Ah, okay! Maybe not the R5 1600 then... Which country?
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614146
Indonesia. and its klevv SSD good?. when i go Crucial BX500 240gb its add like 10$ to KLEVV n500. so i choose klevv. and for the psu im still looking for CX 450. its available 550 around 64$ that a lot
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614153
why didnt you say so how much rupiah can you spend?
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614162
cuz dollar its like worldwide known.  max 7million iDR
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614165
Doesn't matter though, for the simple reason that dollars aren't directly comparable to your country. Always post using the currency of your country, otherwise you're going to get pricing that isn't at all relevant to you, as you've already seen.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614184
I only put the crucial bx500 in the PCPP list because it didn't have pricing for the klevv sdd. Just chose something that was a comparable price to what you specified.
Do you have a link to the part stores so we can see what it's available and pricing?
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614196
https://www.enterkomputer.com/ use that or Tokopedia
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614202
enterkomputer.com
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1069108-help-build-pc/#findComment-12614444
