The 4 Phase VRM on the ASRock is a bit rubbish, I would avoid it.
Gigabyte has my vote out of those 2
Intel 12400F | 2x8 3000Mhz Corsair LPX | ASRock H570M-ITX  | Noctua DH-N14 | Corsair MP50 480GB | Meshilicious | Corsair SF600Fedora
Thanks let me know if I said something useful. Cheers!
definitely gigabyte there boards are great for over clocking with there great VRM
 CPU: i9 9900k @5.1ghz | GPU: Asus Strix 2080Ti OC | Cpu Cooler : Corsair H150i (360mm) | Motherboard: Gigabyte Aorus Pro Z390F  | RAM: G.Skill Trident Z RGB 32gb 3600Mhz CL16  | Boot / OS SSD : Samsung 970 Evo 500gb M.2 / Samsung 850 Evo 500Gb SSD / 1TB SEAGATE HDD Case: Corsair Obsidian 500d SE RGB | PSU: Evga SuperNova Platinum 8
It all depends on the models, no all models are the same, some brands have better VRMs on some and weaker on others.
For the 2400G CPU the asrock  B450M-HDV will do just fine. Like for every build as long as you have a decent air flow the VRMs won't heat as much even overclocked.
Asrock. S2H is such a basic board that I would not recommend it. Esp not for CPU-IGP OC.
https://www.techspot.com/bestof/amd-b450-motherboards/
Though if you can stretch a bit further with your budget, a B450M Pro4 would be more sensible option.
Life is really challenging. I don't always suceed: )
If OP ever wantd to move to an overclockable 8 core, they would need a new mobo
