Whats the best under £20 CPU I can put in this mobo ?
https://www.ebay.co.uk/itm/G41-Motherboard-LGA-775-DDR3-Support-Dual-Quad-Core-CPU-for-Desktop-Computer-/143019222765
Edited by LogicalDrm
If you want me to see your reply, please tag me @Faisal A
https://linustechtips.com/topic/1068778-best-cpu-for-mobo/
12 minutes ago, Faisal A said:
i'm absolutely confused if thats lga 1366 or 775
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1068778-best-cpu-for-mobo/#findComment-12611377
https://linustechtips.com/topic/1068778-best-cpu-for-mobo/#findComment-12611416
Yea dude, same here
Also @Faisal A you have the board already?
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/1068778-best-cpu-for-mobo/#findComment-12611423
Apparently people list motherboards specifically under LGA771, if you don't have your motherboard already maybe one of these might be a better choice for better cpus.
https://www.ebay.co.uk/itm/Jia-Huayu-Professional-Mainboard-P45-Socket-LGA-771-DDR3-Memory-8GB-Compute-M9/323713630382
It's also P45 chipset, which is better than G41 and cheaper. Just make sure if you buy a "pre-modded" cpu to remove the sticker on the bottom bridging contacts. You might want to try to find one that isn't modded if these are a proper LGA771 socket which they seem to be.
https://linustechtips.com/topic/1068778-best-cpu-for-mobo/#findComment-12611431
