my ryzen 2700x is stuck on the prism cooler
I have been soaking it in alcohol, used q-tips soaked in alcohol to get thermal paste off the sides, also tried credit card and floss.like this
should i try a hair dryer to heat it up?
I have tried for 2.5 hours and it still doesn't budge. i can't get the floss under it
its the paste pre-applied to the prism cooler
before cleaning
after cleaning. i just managed to remove the thermal paste from the sides
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/
I usually use a credit card to wedge under there ever so slightly, then very very gently turn the CPU around on the cooler until an edge slips off. Once an edge has slipped, the rest is usually pretty easy to get.
In the future, consider powering up your computer and letting it run idle for 5-10 minutes before trying to pull the cooler. That will heat up the thermal paste and soften it up some, making it easier to remove the cooler without removing the CPU.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12610871
I had a similar issue with am3 (also pga) try sliding the cpu off (by holding the pcb of the cpu.
Current main PC:
CPU: R7 7800x3d (PBO undervolted)
GPU: 7900XT
RAM: 32gb Gskill Ripjaws S5 6000mhz
MOBO: Asus TUF B650e wifi
CASE: Xtia Xproto ATX
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
RAM: Assorted 4gb sticks (24gb total)
MOBO: Asus Sabretooth X58
CASE: Alienware Area 51 ALX
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12610873
This usually works for me, just spinning the CPU like you're unscrewing a screw until it slides off. However, if you really have to force it to get it to spin then that might not be a good idea.
~Air Cooling Advocate~
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12610896
first thing i tried. tried again still strong
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12610898
tried it, also tried floss and q-tips
been soaking it with rubbing 96% alcohol during the process
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12610899
it was on the bios for about 30 mins before i started
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12610900
Well the bios creates very little heat (almost no load on the cpu) The hair dryer may work but I would worry as I don't know if it creates static electricity. if your cpu is really that adhered to the cooler you could try something stronger than a credit card (sheet metal or a small screwdriver.
Current main PC:
GPU: 7900XT
Server PC:
CPU: Xeon X5690
GPU: R9 Fury X
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12610904
None of this is correct. BIOS tends to run 10-15C above idle in my experience. Not like putting it through AIDA64, but definitely warmer than just sitting on the desktop. As long as the computer is on and power is going to the CPU, that's all you need. Most of them idle around human body temperature, and that's more than warm enough to loosen up just about anything between Elmer's glue and liquid metal.
A hair dryer can cause an electrical discharge that will kill the motherboard, so this is definitely not something to do two inches above your VRMs or RAM. With enough distance between you and the motherboard, this is safe to do on CPUs.
Do not, I repeat, do not ever use sheet metal or a screwdriver to remove a CPU. For one, that will scratch up the CPU's surface and void the warranty. Two, it will trash your cooler's baseplate. Copper and aluminum are very soft metals. Screwdrivers and sheet metal are not. They will win the fight, and when they do, they will destroy the cooler. Three...do you really think jamming a screwdriver or a piece of sheet metal under your CPU to pry it loose is in any way a good idea? You're not loosening the CPU. You're creating a very expensive catapult with no warranty.
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12611018
its stuck on the cooler its, not on the mobo. I already ordered the arcticlean @Ak_An said so if that fails I will try the dryer
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12612475
On 5/31/2019 at 9:27 PM, Ak_An said:
https://www.amazon.com/ArctiClean-60ml-Kit-30ml/dp/B0007TOR08
This stuff eats though thermal paste maybe you could try it
they didn't work
after i tried the arcticlean and failed i tried the hair drier (i pointed it on the heatsink and heated the heatsink only). which also failed.
idk what else to do
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12620080
2 hours ago, Technomancer__ said:
they didn't work
idk what else to do
What I have heard people in the past do is have the CPU in the socket, run a stresstest for 10 minutes, shut down the PC and immediatly try to take the cooler off. The heat sometimes softens the thermal paste which makes it possible to take off the coolers.
This is somewhat 'dangerous' though, since you can't see the gold triangle anymore.
Tbh, maybe a tool with a bit more force could work, like a screwdriver or metal spudger. You have to be super careful though, as you obviously don't want the CPU too get flung off the cooler.
Although, if you have a plastic spudger I would honestly try just 'digging' into the thermal paste. A plastic spudger will not damage the cooler or CPU, which means you can go pretty deep with it. They are usually sturdier than a creditcard too, meaning you can apply some more pressure too.
Maybe a combination of heat and a creditcard will do the trick.
https://linustechtips.com/topic/1068703-cpu-stuck-on-cooler/#findComment-12620567
