Hey
I have 8700 with Hyper 212 cooler on it,
When I play games which are cpu intensive like far cry 5, my temps keep fluctuating from 70 - 87 with max 38% usage, are those temps fine ?
Also recently had a black screen while playing far cry 5 , (No Signal) on monitor, I did some research and many people suspect psu or cpu temps. So I just need a solution for the temps and this random black screen issue (I was gaming for non stop 5 hours) when the black screen appeared.
My specs
i7 8700 (non k)
Gigabyte b360m
1080 Ti Armor OC (with temps around 80c)
16gb ddr4 ram Hyper x
Corsair TX 650M
cpu cooler Hyper 212 (I know it's average but still just for 38% usage temps are too high)
Thank you. :)
https://linustechtips.com/topic/1068456-high-temps-on-8700/
Can you show us how your PC looks like? these temps are indeed higher than they should be, I have an i7 8700 myself on a Hyper 212X and I get 68Cº on max load while overclocked to 4.45ghz all cores.
So either you mounted something wrong or your case has extremely limited airflow.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1068456-high-temps-on-8700/#findComment-12608931
Probably a win 805 infiinity
Current PC (Second Build) : CPU: Ryzen 5 1600 (OC @3.8GHz, sometimes pushed to 4GHz) RAM: 16gb Corsair Vengeance RGB Pro DDR4-2666 (OC @2733Mhz, sometimes pushed to 2800 for testing purposes)   GPU: PowerColor Radeon RX570 8gb MOBO: ASRock B450m Pro4 SSD: Inland 120gb HDD: 1tb Seagate Barracuda PSU: Cooler Master Masterwatt 500w Lite Case: NZXT H500 OS: Arch Linux+ KDE Plasma [Desktop Environment] & Windows 10 Pro [Broken due to grub 50% of the time]
Accessories: Mouse: Alienware AW958 Elite Keyboard: Corsair K63 Wireless  Headphones: Samsung Level On Pro
Phone (waiting on arrival): Samsung Galaxy Note 9
https://linustechtips.com/topic/1068456-high-temps-on-8700/#findComment-12609013
