Computer Without hard drive?
Go to solution Solved by Electronics Wizardy,
Most all modern pcs support pxe booting from a network boot server, but really, just have a small ssd for the os, makes working with it much easier.
is it possible to have a computer boot from a storage server?
my idea is to have a storage server with a few drives in some raid configuration and have it accessible from anywhere, but the catch is i would like to have another computer use this storage structure as its C: drive access via network cable.
i haven't worked out any particulars yet as this is still conceptual.
Thanks for any help
Processor:Intel i7 5930k,     Motherboard:Gigabyte X99-UD4,     RAM:32GB ddr4,     GPU:2x GTX 770 SC,     Case:Corsair 780t,     Storage:2TB hard drive, 120GB SSD, 1GB external hard drive,
Power supply:cooler master v750 semi-modular,     Monitors:2x Philips 23" 1920x1080,     Cooling:XSPC raystorm water cooled CPU, 6 coolermaster jetflo 120mm fans.
https://linustechtips.com/topic/1066507-computer-without-hard-drive/
my idea is to have a storage server with a few drives in some raid configuration and have it accessible from anywhere, but the catch is i would like to have another computer use this storage structure as its ? drive access via network cable.
Thanks for any help
Wouldn't that be basically virtualization?
I once gave Luke and Linus pizza.
Proud member of the ITX club.
**SCRAPYARD WARS!!!!**
#BringBackLuke
yea figured as much, thanks
I run my ESXI off of a flash drive, and Unraid recommends the same.
Dedicating all the local drives to the data store is a perfectly reasonable thing to do.
Intel 11700K - Gigabyte 3080 Ti- Gigabyte Z590 Aorus Pro - Sabrent Rocket NVME - Corsair 16GB DDR4
