Help with a stupid question
Solved by Kitsune001,
3 hours ago, Mikensan said:Also I would look at something like Worldgen (not sure if that's the correct name or if it still exists) to pre-render the map, will really help reduce lag as people explore.
I search and is a worldpainter for minecraft that way I can make a custom map with no problem and the server don't need to render the map best idea
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
Posted in New Builds and Planning9
