power efficient CPU for gaming
Go to solution Solved by Fasauceome,
Third gen Ryzen processors are proposed to be far more efficient than current gen, you should consider waiting for the data on the new processors before you make a decision.
I currently have the I3-8100 in my build.
using power monitoring apps, the CPU package peak wattage was 35 watts (28 average while gaming), the I3-8100 also does not have a boost clock, I managed to undervolt it a bit reaching 30W of peak wattage usage, but if i want to upgrade my CPU now, what should I pick for for more power efficicieny (the most power efficient upgrade regardless the price) and I cant go higher than 60 watts, it is only for gaming , I thought about the I3-9300 or the I3-9300T since it has a good boost clock but I have no idea how far can this boost take up more power and if there will be remarkable difference, I have no idea at all about other CPU power usage, the TDP refers to nothing....
I am also thinking about the I5-9600T or I5-9400T but don't know if they will be power efficient, 8700T, 9700T, 9900T too, i know those are very expensive but I need to have an idea about their power efficiency, however some people said that K processors can be as efficient as T series when underclocked, but I still believe it is not due to high base clock and thermal design, any idea??
https://linustechtips.com/topic/1064800-power-efficient-cpu-for-gaming/
They’re all 14nm and pretty much the same architecture so they will generally use about the same amount of power. I would go with the i7 8700t or 9700t since they have more cores.
 Why are you trying to run your desktop cpu at a lower tdp than most laptops?
I don't like laptops and I want a power efficient desktop, I also like to look at the internal parts which are invisible in laptops, I am also using solar system so low power is an important element for my 24/7 always on desktop
I5-9600T has even more cores than the I7-8700T, but as far as i know more than 4-6 cores won't matter anymore for gaming so i would go for the more power efficient one and i still don't know if they take up more than 60 watts
Primary PC:
PSU tier list
How many watts do I need?
First off a solar powered gaming pc is awesome. Second, it depends on what you’re playing. Newer games are taking advantage of more cores, so I would personally recommend at least 6 cores now. The 8700t has hyperthreading which can help in certain workloads, but I don’t think it matters much for gaming.
dk but as rumored they are 7 nm power hungry chips.
i5-9600T has 6 Cores and 6 Threads, while the i7-8700T has 6 Cores 12 Threads, which is far better
And no, that used to be the case but not these days, games scale well even above 8 Cores, but the sweet spot seems to be 6-8 cores, but anyway I would also recommend the i5-9400F if you have a discrete GPU, shouldn't consume more than 60W, probably a bit less than that
not sure about that since the i3-8100 take way less power than the I9-9900 non k
You're comparing a 4 core 4 thread CPU with an 8 Core 16 Thread CPU :|
Quote or Tag people so they know that you've replied.
The wattage is based off of their base clock. When they boost up they will use more power than their tdp rating. That is why the 9900 will use more power.
The 8700t has like a 2.4ghz base clock while the 8700k has a base clock of 3.7
sure but I won't go for more than 60 watts, it will be dam hell, I prefer to give the extra watts to my next GPU upgrade, I currently have the GTX 1060 running at 60 watts
What power supply do you have? If you’re looking for power efficiency it is also important to make sure you have an efficient power supply.
i got a good EVGA 500W 80 plus bronze one with Erp Lot 6, going for more efficient power supplies will cost alot while it may save only 10 watts, however i still consider that
I wont spend more for T chips if that's the case, even on cheap boards you could limit the CPU's frequency and voltage.
Desktop benching:
I think i may use your notice as a way to expect power usage
I agree but will that give me good power value as T series do? I have no idea about the differnce, but from some sites I saw a recorded peak power usage for I7 and I9 and they were very very high tho, it may not be the case with i9-9900T, dk the difference
the only game i know that get benefit from 6 cores is Hitman 2 so the 2 extra cores could be helpful for background things, but I have almost nothing in the background but still considerable
Keep in mind that K skus or ryzen chips are unlocked, therefore can be multiplier under-clocked and under-volted to whatever power target you want, so long as you can test for power usage and stability effectively. A 9300T uses less power because it has a lower base clock and voltage and is programmed to scale only to specific power targets. So it's plug and play low power draw, but you can do the same thing manually too.
AMD announced that the 7nm node would double the efficiency. I have heard no rumors about Ryzen 3000 being power hungry
Primary PC:
PSU tier list
do all coffelake cpus come with the same efficiency? does hyperthreading require more power? does going for higher baseclock less efficient?
because they didnt underclock, most likely didnt undervolt either.
yes, along with higher speed. Efficiency doesnt change
Desktop benching:
hoping tho, from what i got is that they take more than 60 watts but i can underclock them a bit, seems confusing, is double the efficiency better than current 14 nm intel coffelake processors? edit: it should be better ?
There is some conjecture that T series are cherry picked just like K series are, but with little physical evidence that I've seen.
Higher baseclock requires more power, but is not necessarily less efficient. There are two means of measuring efficiency. Instructions per clock and performance per watt. Performance per watt is similar in function to performance per dollar. More in depth reviews like those I've seen an AnandTech assess Performance per watt.
