usually no, as home use boards stop the boot process if they dont detect a monitor and a keyboard.
Server boards then yes, they mostly run with power and internet connection plugged in only anyway
Desktop benching:
13 minutes ago, XR6 said:
Yes, it'll post but you won't see anything on the screen due to your CPU not having an iGPU.
POST stands for "Picture on Startup", so the first part of your answer contradicts you second part :P
which board do I have?
home use board
Desktop benching:
Nahh ima have a monitor and keyboard I am just talking about a gpu not being there
if you dont have a GPU there's no way you can use a monitor and get it to work.
Desktop benching:
