If you are okay with used hardware, I would TOTALLY recommend that you go to eBay and purchase a GTX 1080ti. They are like $520ish with Free shipping, and better than that they perform better than the RTX 2080 in most applications. With your budget, you could even afford two of them and put em in SLI if you really wanted. You can even find some of the limited edition SC2 watercooled EVGA cards if you look hard enough.
Ive bought my last two GPUs through eBay and had awesome luck as well as got awesome deals, but YMMV
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551112
6 minutes ago, Chris Abercrombie said:
I'm in the US, 60hz might upgrade to 144hz but its what I have. I'll play FPS, Strategy (Wargame specifically), and Forza. I have a budget of the 2600 for the computer as a whole.
1080p is a big market. For high refresh rate with Ultra settings, it narrows down to:
GTX 1660 ~ RX 590 < GTX 1660Ti < Vega 56 < RTX 2060 < Vega 64 < RTX 2070
And the Vega 64 and RTX 2070 both lead nicely into 1440p gaming if you wanted to upgrade in that way.
In the U.S. the Vega cards are on super nice prices currently, so it's hard not to make the Vega 64 my suggestion.
For price to performance, I'd say this model is what I would do if I were in the market:
https://pcpartpicker.com/product/MssmP6/sapphire-radeon-rx-vega-64-8gb-nitro-video-card-11275-03-40g
Though as high as your budget is I'd do a Redeon VII or RTX 2080 just to do it...
Are you in the US?
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551120
2080 then, and a EX920 + Seagate 3TB
PCPartPicker Part List
Type Item Price
Storage HP - EX920 1 TB M.2-2280 Solid State Drive $124.99 @ Newegg
Storage Seagate - Barracuda 3 TB 3.5" 7200RPM Internal Hard Drive $74.99 @ Amazon
Video Card Asus - GeForce RTX 2080 8 GB ROG Strix Gaming Advanced Video Card $759.99 @ Newegg
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $989.97
  Mail-in rebates -$30.00
  Total $959.97
  Generated by PCPartPicker 2019-05-08 16:44 EDT-0400
perhaps try to squeeze in a 1440p 144hz
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551121
Yeah I have no idea what SLI is nor do I know what 1080ti would be better performing.
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551122
I wouldn't. SLI is when you bridge 2 GPUs together for added performance, but these days the support is lacking.
In most use cases that money would be wasted, or even hurt your gameplay.
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551124
Are you in the US?
Yeah I'm in the US. Which of the two are better for gaming?
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551126
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551145
1 minute ago, Chris Abercrombie said:
I plan on having a glass side on the side so would an air fan be the best?
I'm personally more a fan of air coolers
let's say it softly that it's a question of preference
tho aircoolers are generally cheaper for the same or better performance
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551161
I'll look into it I dont want the PC to be loud anyway I'm just not sure about it because of the glass.
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551168
cases have measurements for how high it can come
it'll look kinda like this (as example)
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551173
2 minutes ago, LukeSavenije said:
okay-ish if you can get a deal on it
but airflow isn't that good compared to models with the prices i can see
It's $80 on amazon right now. Could you recommend some better cases? I'd really like to have a glass side.
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551189
oh... i looked into it
because i selected the quite big hx750 it doesn't even fit
but that aside, i think you're getting a great deal with the cooler master h500 i linked above, it has freakin 200mm fans in the front
I'd recommend it with the in the box mesh panel for the best airflow
https://linustechtips.com/topic/1062230-gpu-recomendations/#findComment-12551205
