i just got my new gpu gtx 1080 and i plugged it in and its getting power but when i press the power button on the the gpu lights up and stuff but the fans spin like crazy at 100% and im not getting any  display tried plenty of stuff and nothing and yes when i unplugg the gpu and use the mobo everything works fine its just the gpu is getting power the fans are spinning like crazy and when in bios its not getting detected by the pcie slot
tried ram slots, cms battery, rebuilt the pc check everything plugged in properly same thing all the time
my system spec i got last week too all brand new nothing used
9600k
16gb 3000
msi z390 a pro
cxm 550
https://linustechtips.com/topic/1061949-help/
Check if your graphic card is correcly pluged in to your monitor (EDIT: do you plugged card to your monitor, not mobo? wink wink), check if you properly seated card in PCI-E slot, try different PCI-E slot if you have more than one and last one check card on friends computer.
ah also once someone forgot to plug pci power cables to card - check that to.
https://linustechtips.com/topic/1061949-help/#findComment-12548295
tried that and nothing and yes it worked on a different computer
https://linustechtips.com/topic/1061949-help/#findComment-12548318
It worked in a different PC? Thats weird...
Try updating the BIOS on your motherboard, as well as the VBIOS of the card.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1061949-help/#findComment-12548335
Just now, Sorenson said:
make sure you don’t have drivers for another graphics card installed on your computer. I would recommend using DDU.
i do have the 9600k intel i gpu installed do i use ddu to uninstall that too ? and please explain this when its plugged and turn the pc on the gpu fan go insane
https://linustechtips.com/topic/1061949-help/#findComment-12548349
no, just any dedicated card graphics. i had a defective asus 1080 that did something similar. i had to RMA it.
https://linustechtips.com/topic/1061949-help/#findComment-12548359
14 minutes ago, Sorenson said:
Do you have the motherboard supplemental power plugged in? do you mind posting a picture of your motherboard with everything plugged into it?
every thing is plugged in fine i made sure of that literally only issue is trying to get display from the gpu
https://linustechtips.com/topic/1061949-help/#findComment-12548491
So I would try a different graphics card in your computer if you have access to one to test your motherboard. Otherwise return/Rma your graphics card see if that fixes it, if that doesn't work its probably the motherboard.
https://linustechtips.com/topic/1061949-help/#findComment-12548512
