Low speed with two separate cables
Solved by Scheer,
If any one of the eight wires are broken, it drops from 1gbps to 100mbps, you likely just have a bad spot in the cable somewhere.
If you have a volt meter, you can do a continuity check on each wire on both the cables and adapter. If the cable and adapter test good it could be a setting in your network adapter, or you might be connected to a 100mbps port on a switch/router somewhere.
