Optiplex 390 0m5dcd Front Panel I/O Pinout (need help)
I've managed to get my hands on a working Optiplex 390 and was able to measure the cables. Will post a solution when i have time to actually apply the fix to the board in case someone else needs help solving this. There is a 3 pin short on the 16pin cable, and two more shorts -> one on the audio cable and one on the left usb; if any of these is missing you will get the i/o cable failure message.
Audio and USB:
16pin header:
EDIT: for the 5pin PWR_SW pinout -> use black + yellow for PWR_ON (actual power switch) and short red + yellow to get rid of the error. I don't have the board anymore so had to use google, but this is the way i wired up mine. I have to add that at first i shorted red and blue out of convenience but the board would randomly refuse to power on at times, this was fixed after some soldering to connect it the proper way.
p.s. Dell is hell
