TWMC,
I’ve always had really high ambient temperatures in my room during summers. It was refinished from an attic storage room, and I live in the south.
I’ve tried air coolers and AiO’s to cool the CPU, but in summers, I hit around 90°C max on my CPU. I’ve decided to buy an active chiller to reduce my temps down to something more reasonable i.e. 50’s to 60’s max.
I have an EK custom water cooling system on the way, but I feel like I need something actively dropping temperature below ambient to get good results.
I watched the video on chilling threadripper 2, but the aquarium chiller is no longer for sale. Is there any other chiller under $300 that’s not garbage?
Thanks in Advance
https://linustechtips.com/topic/1060489-consistent-subambient-cooling/
IMO it would be cheaper in the long run to get a half decent AC system for the room, rather than trying to cool the CPU itself... just my opinion.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Subambient temperatures will cause condensation. Condensation will cause PC death. Get AC.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
19 minutes ago, TechSwagPimp1337 said:
Update: It could cost a lot of money to get an AC that could dissipate heat outside of my room, so that is out of the option. The cheapest solution would be to get a chiller for the PC.
So for a chiller you can get Hailea chillers, for most people just going sub ambient the HC300 or HC500 would be enough.
However, in a hot humid attic room, going sub ambient is just asking for trouble, you WILL get condensation and it WILL eventually kill your system.
The advice about an AC is best. grab a small portable AC.
Beyond that ur looking at building either a dry gas case to prevent condensation and then chilling the loop using a chiller, or building a chill box where you chill the air inside as well as the loop itself, and use a desiccant to absorb as much moisture as possible, condensation forms on the coldest part which should be a radiator circulating air inside the box. Both require some DIY and have costs involved, and both require condensation protection being used on the components, such as dielectric grease, liquid electrical tape, neoprene, etc.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Condensation is a result of temperature and relative humidity. The goal is to have the chiller set to around 40°C, well above the dew point for the room. Condensation will not occur in the PC at 40°. I’ve done the calculations.
Portable ac units cost almost as much as chillers, but I’d be using more power over all running the AC vs the chiller.
What I need, and what I asked for, is a good deal for the chiller.
So ... the chiller ..of which i already recommend which ones to get ... where is it going to be located ? in the same room ?
Yes. Same room. Right beside the PC. At 50°C and 60% humidity, the dew point is a little over 40°, but I'm going to have a micro-controller on it to run it at least 5°C above the dew point at all times. Labview FTW.
I honestly don't know how well a chiller would even operate at such ambient temps, thats toasty to say the least. I'm surprised you can stand it ur self to be honest.
I dont know what ur situation is , but maybe you should consider having the chiller in another room that isnt so hot, and run tubing from it to the PC. That would get you away from the noise of the chiller and allow it to run more effectively. In regards to temps though, 40c liquid temps is still very warm, ur likely still going to be looking at high operating temps for the PC.
I'd suggest building a cheap cool box for your PC, running the chilled liquid through a rad inside the box and some fans circulating the air , reducing the box temps allowing u to go lower on the loop temps. Wouldn't cost much tbh, some wood and some foam for insulation to keep the cold air in.
