CPU:i5 7600k
MOBO: Gigabyte GA-B250M-D3h
RAM: 8gb at 2666 MHZ
GPU: EVGA gtx 1080ti FTW3
The problem occurs while playing Battlefield 5. I'm playing on 2440x1440 resolution witch is native to my monitor. I've tried playing on max/low settings, trying to with DX12 and without and so on. The CPU usage is staying at 95-100% while GPU never reaches double digit. There is not thermal throttle.
 I've run skyheaven benchmark and it worked fine with cpu at 50% and gpu at 100%
https://linustechtips.com/topic/1059646-cpu-running-at-100-while-gpu-at-1-2/
What kind of performance are you seeing with 2% gpu usage?
Edit: my 2cents: you are accidentally using the iGPU and not the dgpu. Try setting windows to high performance mode and see if that helps.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
6 minutes ago, TheUser11 said:
CPU:i5 7600k
What do you use to monitor your hardware?
If you're seeing very high CPU usage, with low GPU usage, I would assume your PC is accidentally using your Intel GPU instead of your Nvidia GPU. Fixing this is very simple. Right click on your desktop, and launch the Nvidia control panel. Under "video settings" (or something similar) you see a tab where you can select your GPU. If my suspicions were correct, then it should say "integrated GPU" or "Auto." Change it to "Nvidia high-performance GPU" (or something similar), click apply, and you should be done.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
i've got anywhere from 40 to 70 fps. But mostly low 60/mid 50.
Well that's impossible, have you checked the second thing?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
it's impossible to be rendering 70fps on BF5 with just 2% of GPU usage.
Either ways with a 4c/4t I'm not surprised your CPU is maxed out and it's bottlenecking the GPU, eveything seems in order aside the GPU usage you're describing, I'd ditch EVGA's software and use MSi Afterburner+RivaTurner.
Personal Desktop":
Luna, the temporary Desktop:
I've tried every solution offered to me in this thread and used MSI afterburner. I'm still gettings GPU usage from 40-70% while usage was still 100%. Is that considered bottleneck?
Yes sir, your CPU is already 100% usage maxed out, it's trying to tell the GPU what to draw/render as fast as it possibly can but it's not fast enough for the GPU to reach it's full usage... so the CPU (and likely your memory configuration if I'm honest) are bottlenecking the full potential of your GPU.
Personal Desktop":
Off the topic question. Do you think I should wait for new ryzen 3850x or go with i9 9900k. I'm asking because I see you got one.
1 minute ago, TheUser11 said:
It's 2 months away for Zen2 release... do you think you can live with your PC as is for that long? if so then yes you should totally wait as competition is good for the market.
Personal Desktop":
I'm considering buying the i9 now and sell it of when amd releases, but I'm quite scared how much will the price drop on the i9 after amd release.
