S.M.A.R.T. Result
Go to solution Solved by SupaKomputa,
Yeah it's normal.
The drive has been running for 42801 hours, that's 5 years, and the power on count is only 80, so it was running constantly
the drive doesn't show that anything is wrong with it, but don't trust it with your personal data, in fact don't trust any drive with your personal data
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1059275-smart-result/#findComment-12523257
That's a really small picture, but does it have 42000 hours and power on count 80? That would mean it was used on a server. 42k hours is close to 5 years.
Intel Core i9-9980XE 18c/36t, Asus TUF X299 Mark 1, 128GB DDR4 3200MHz, Palit RTX 5070, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, Meshify 2
PC 2: AMD Ryzen 7 3700X 8c/16t, MSI X470 Carbon, 32GB DDR4 2666MHz, Asus GTX 1080 Strix, 512GB Samsung PM981, 1TB Crucial MX500, Fractal Define R4
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 48GB DDR3 1600MHz, EVGA GTX 970 ACX 2.0, 500GB, 250GB & 120GB SSD, 10TB & 2x 4TB HDD, Fractal Define R5
PC 3: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Phone: Samsung Galaxy S23 256GB Watch: Samsung Galaxy Watch7 44mm LTE
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
Z77: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 32GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
https://linustechtips.com/topic/1059275-smart-result/#findComment-12523258
yeah i just counted that and think im just using it for files and films, i will use SSD on the rest of my stuff tbh. but thanks for the advise i will keep my personal data away
https://linustechtips.com/topic/1059275-smart-result/#findComment-12523261
i can get it lower maybe just say its used for 5 years maybe the price is gonna lower a bit (hope so)
https://linustechtips.com/topic/1059275-smart-result/#findComment-12523263
So you haven't bought the drive yet? I wouldn't pay more than 10€ for it. It's been running 24/7 for 5 years and that's a lot.
Some other PC's:
https://linustechtips.com/topic/1059275-smart-result/#findComment-12523275
i dont know if i can get it that low tbh, maybe like 20euro (different in currency is kinda a lot)
2 minutes ago, GoldenLag said:
google drive.
infinite ammount of Datastorage for like nothing. a lot people are abusing it.
well google is very kind than, thanks for that
https://linustechtips.com/topic/1059275-smart-result/#findComment-12523281
2 hours ago, noxdeouroboros said:
Not nothing though, but yes, very cheap.
2 hours ago, GoldenLag said:
for "infinite storage" i would put it was quite cheap.
well im still in highschool, so its like 1/3 of my monthly allowance i dont think i will use it before or after college
https://linustechtips.com/topic/1059275-smart-result/#findComment-12523757
10.4€/∞ GB makes for 0€/GB, so yea that's quite cheap
But it's Google you're giving (more) of your data to. So it's a no from me
75% of what I say is sarcastic
So is the rest probably
https://linustechtips.com/topic/1059275-smart-result/#findComment-12523804
