I am planning on building my first build after a few years of watching Linus and the pc crowd. I have done a lot of research and would like to hear all ya'lls opinion on my choices. My goal was to build that was VR ready, and capable of light to medium photo/video editing and airflow is a heavy priority. If there's anywhere you believe I can save money or suggest an upgrade all comments would be appreciated! Also, I can't find a good case with front USB-c support.
Here is my current build...
https://linustechtips.com/topic/1059204-first-build-critiques/
-= Moved to New Builds and Planning =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522653
7 minutes ago, Sailboy42 said:
For $1 more you can get the black edition, the evo just has no place anymore with its price so high.
Only splurge on the drive speed when video/photo editing is a main priority. An NVMe SSD is not useful in a gaming PC.
try this out:
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522655
4 minutes ago, Sailboy42 said:
Probably don't need 32GBs of RAM, should go for one of the gigabyte aorus B450 boards
Should get a 500GB SSD for that price, 2TB drives shouldn't cost that much.
Could go for a case with a bit more airflow.
You can use windows 10 for free or just get a cheap key from ebay.
What monitor resolution/refresh rate?
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522656
10 minutes ago, Sailboy42 said:
almost there... get ryzen 3000
this board is just expensive as usual, also get faster ram, 3000+
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522662
18 minutes ago, Sailboy42 said:
snip
Swapped the motherboard for the MSI Tomahawk, also 3000Mhz RAM as Ryzen likes fast RAM
PSU for the cheaper on-sale Seasonic
Removed W10Pro
PCPartPicker Part List
CPU: AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor  ($179.99 @ Amazon)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.89 @ OutletPC)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($114.88 @ OutletPC)
Memory: G.Skill - Ripjaws V 32 GB (2 x 16 GB) DDR4-3000 Memory  ($155.98 @ Newegg)
Storage: Samsung - 970 Evo 250 GB M.2-2280 Solid State Drive  ($99.69 @ OutletPC)
Storage: Western Digital - 2 TB 3.5" 7200RPM Internal Hard Drive  ($104.95 @ Amazon)
Video Card: Gigabyte - GeForce RTX 2070 8 GB WINDFORCE Video Card  ($478.99 @ SuperBiiz)
Case: Phanteks - Enthoo Pro M Tempered Glass (Black) ATX Mid Tower Case  ($95.98 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 650 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($61.98 @ Newegg)
Keyboard: Rosewill - RK-9000V2 BR Wired Standard Keyboard  ($64.99 @ Amazon)
Total: $1492.27
Generated by PCPartPicker 2019-04-28 23:01 EDT-0400
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522672
17 minutes ago, Sailboy42 said:
photo/video editing
You'll be better served with Intel, I'd say try out 16GB first and only add another kit for a total of 32GB later if you feel you truly need it.
Run Windows 10 unregistered for a while, no need to pay such an expensive price tag for what you can use for free.
CPU: Intel - Core i7-8700 3.2 GHz 6-Core Processor  ($294.99 @ Walmart)
CPU Cooler: be quiet! - Pure Rock 51.7 CFM Sleeve Bearing CPU Cooler  ($35.89 @ OutletPC)
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard  ($69.89 @ OutletPC)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-2400 Memory  ($76.89 @ OutletPC)
Storage: Western Digital - Blue 500 GB M.2-2280 Solid State Drive  ($64.89 @ OutletPC)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: Gigabyte - GeForce RTX 2080 8 GB WINDFORCE Video Card  ($699.99 @ Amazon)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($45.28 @ Amazon)
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($63.98 @ Newegg)
Total: $1406.79
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522674
It's unlikely to be the kind of heavy workload that would really show a difference.
As well an R7 1700 is still $160 and really hard to beat in terms of value.
His PC probably doesn't need to go over $1000-1100 total.
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522676
@Sailboy42 your hard drives are pretty expensive for HDD's the WD blacks are, from my understanding, usually used by video editors. Since you have two of them i'm assuming you want to raid 0 them. Instead I would suggest using a Seagate Firecuda drive instead. I've tried raid 0 with HD's and it still feels really slow compared to solid state drives. The firecuda is a hybrid drive with an 8gb sdd for exceleration. It really helps if you're using it for gaming after the first load. I'm using one in my PS4 pro and i'm really happy with it. Also the Firecuda is cheaper.
One thing to keep in mind is stock case fans are usually loud, so you might want to budget for adding some nice magnetic levitation fans (bonus they are quiet). Also with ryzen you should try to get ram around 3000 mhz speed.
https://pcpartpicker.com/product/NpBrxr/seagate-firecuda-2tb-35-7200rpm-hybrid-internal-hard-drive-st2000dx002
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522720
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor  ($223.89 @ OutletPC)
Motherboard: MSI - B450-A PRO ATX AM4 Motherboard  ($84.99 @ B&H)
Memory: G.Skill - Aegis 32 GB (2 x 16 GB) DDR4-3000 Memory  ($145.98 @ Newegg)
Storage: HP - EX900 500 GB M.2-2280 Solid State Drive  ($64.89 @ OutletPC)
Storage: Toshiba - X300 4 TB 3.5" 7200RPM Internal Hard Drive  ($104.99 @ Walmart)
Case: Fractal Design - Define C TG ATX Mid Tower Case  ($88.38 @ Amazon)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($99.49 @ SuperBiiz)
Keyboard: Logitech - G413 Silver Wired Gaming Keyboard  ($52.95 @ Amazon)
Total: $1629.53
Generated by PCPartPicker 2019-04-29 02:06 EDT-0400
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522857
Yes, I was planning to run them in raid. I'm surprised though that they wouldn't be that fast though for such good and expensive drives. I think I will transfer over to the firecudas. I have heard good things about them and coming from someone that uses convinces me.
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522943
Total: $1406.79
Why do you intel? I was preferring Amd due to pricing and the delided processor running cooler.
When you say start off with 16gb of ram I assume you mean running that in dual channel, correct?
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522950
Removed W10Pro
Total: $1492.27
Could you explain why the switch to the tomahawk?
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522951
The 32gbs I believed is good for multitasking with multiple items open such as Photoshop, Lightroom, with music in the background. I also usually leave lots of chrome tabs open.
What in the case makes you say that it doesn't have great airflow. With such an open front I believed it should be fine. Compared to cases like corsair obsidian where there are just small vents that, I believed this was on the better end.
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522963
2 minutes ago, Sailboy42 said:
RAID is pretty pointless for you
you only need 16Gbs at most to do all of that.
The Coolermaster H500 is rather nice
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522970
Its slightly cheaper, and the Tomahawk is one of the better boards at that price point. Good VRMs and power delivery so overclocking shouldn't be an issue.
Also a slight personal preference as I sometimes find ASUS BIOS to be a bit of a faff.
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12522999
No reason to buy anything other than the gigabyte aorus B450 boards at this point. "doubled" 4 phase VRM at $80-100
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12523016
Because Adobe software likes single thread performance more, is more stable on Intel and now with iGPU Acceleration the i7 8700 will render as fast as a TR 1920X
Personal Desktop":
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12523210
Just now, Sailboy42 said:
Does Intel CPUs affect VR support at all?
VR Demands you to push at least 90fps at all times and have more stable minimums.
That is easier to achieve with an Intel processor, now need is a strong word, take it more as a preferable scenario.
Personal Desktop":
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12523753
I do not see anything wrong with other processors than Intel, but it's just that Intel processors are better...
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12524088
1 hour ago, Sailboy42 said:
What is doubled four phase VRM?
You want good VRMs (they help deliver power to the CPU) so you can achieve a better overclock on the CPU. I don’t know what that guys is talking about though, because Gigabyte and Asus have been heavily critiqued on their B450 VRMs. MSI has been well reviewed by hardware unboxed.
The WD blacks are “fast” for an HDD. Hard drive suffer when loading lots of  different small files because it takes time for the reader to move to the different part of the disk. That is where the fire CUDA comes in handy, since those small files will be cached in the SSD after the first load. If you can get the 7200rpm version of the firecuda.
I was wondering about that, what is the estimated date for gen 3 release?
Computex starts at the end of next month. I would expect them to be announced then. But they might not be available for a little while after that. If you go with the Ryzen 2600x you should be able to upgrade to the Ryzen 3000 when it comes out if you decide to later. A lot of people are saying intel is better, but that is only really true for gaming. Although, there is really only a difference in the high end. The difference between a 2600 with fast ram and an i5 is marginal. However, the 2600 will be better at some of the editing stuff you want to do (unless you want to use adobe premiere quick sync which uses the integrated gpu in intel chips to speed up rendering).
https://linustechtips.com/topic/1059204-first-build-critiques/#findComment-12524143
